Tire carrier powdercoat - Defender Source
Old June 19th, 2011, 01:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Contemplating powdercoating the tire carrier on my truck. Can I leave the bushings in? Bad idea? Should I pull them? If so how do I put new ones in? Headset press?
Old June 19th, 2011, 01:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anything that's not metal has to come out or it will melt.
Old June 19th, 2011, 01:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
What are the bushings?
Old June 19th, 2011, 01:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mine are plastic, but its an aftermarket deal.
Old June 19th, 2011, 02:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
I think the stock ones are brass but sure
Old June 19th, 2011, 02:53 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Yes, stock is brass. You can use a brass punch...if you know what you're doing. If you're having the carrier recoated, I would just fit new one's personally.
What tree?
Old June 19th, 2011, 03:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks and how you wrote that without mockery is shocking.
No clue what a brass punch is but I will look it up.
Old June 19th, 2011, 03:52 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
A brass punch is identical to a steel punch, but made out of brass...
You would need to be exceptionally careful even with a brass punch. The chances that they will come out without getting destroyed is pretty nill,......however, you are on the wrong coast, and I'm only accustomed to working on rusty parts....
What tree?
Old June 19th, 2011, 04:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Replacing is fine. I wish the factory bolts could be had for cheap. Over 200 for four.
Old June 19th, 2011, 05:09 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Make sure the powder coater knows what opening/holes will be bushed so he can keep them free of the powder coating. Otherwise you have to hone out the openings for the bushings to fit.
Old June 19th, 2011, 08:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
How does a brass punch work? Looking at the tool and am not sure how you use it to pull a bushing. Are you hitting the inside edge?
Old June 19th, 2011, 08:33 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
The bushing is actually 2 pieces...there is a seam in the middle(inside, duh)...you are far better off just beating them out and replacing with new.....honestly.
But, since you asked, you carefully hit at the seam, working 180 degrees apart and it will come out, then you might need to clean up any "mushroom effect" with a round file......that's if you're really trying to pinch the pennies.
What tree?
Old June 19th, 2011, 10:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
I planned to buy new as they are cheap and I am sure after 17 years worn and yes I have seen them out so I understand the two part. I was wondering more of how the punch works and now I understand. I was hoping there was more of a tool like a head cup remover. Basically a pipe that is split on one end. You pull it through until it is inside the tube sitting on the bushing race and hit it with a hammer to wack it out.
Here is a picture. http://www.parktool.com/product/head-cup-remover-rt-1
Old June 19th, 2011, 10:30 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Get yourself one of these:
http://www.amazon.com/OTC-Tools-OTC1.../dp/B000HI1P68
It made short work of the bushing on my carrier when I replaced them over the winter.
Old June 19th, 2011, 10:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
Very cool
thanks
Old June 19th, 2011, 10:58 PM
NoVaKevin
Kevin
sold#1469
sounds like keeping them in would work great for removing the bushings, no? (although, i doubt the shop doing the powdercoating would like this very much)
Old June 20th, 2011, 08:24 AM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
tire carries
Barry,
Just a suggestion, have you considered having it hot dipped galvanized? I did mine several years ago and have not had to think about it since.
Although powdercoating is nice, unless your truck is garaged all the time and is just a play thing it will not last and you will be doing it again in 5- 10 years. If you really use it as I do mine everyday sooner. As I don't ever plan on selling my truck, I look to do these type of service issues only once.
You can have it sandblasted and hot dipped for typically about $500 and it you want to paint it after that. Go with the aftermarket bronze bushings and new steel bolts. They are half the price of the factory ones and better.
As for changing the bushings, I have done at least 6 of these. All you need is a good bench vise. Clamp the tire carrier in and use a hammer and a steel punch to knock them out. The are split in the center and one half comes out each side. sand the hole to clean up any rust and use a little grease and the vise to press them in.
If you hot dip leave the bushings in place and knock them out after you are done. use red RTV in the grease nipple hole. It will not wash out in the dipping process.
Just MHO. Best of luck in whatever you choose.
Cheers
Here is a shot of mine.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old June 20th, 2011, 08:40 AM
kevkon's Avatar
kevkon
kevin
Nice!
I agree. PC can be good but I have had mixed results in it's longevity.
Old June 20th, 2011, 02:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
Galvanizing is nice but not the look I want. Now galvanized and then powdercoated I could see doing but since my truck isn't in extreme weather I am sure I will just zinc prime and powdercoat. The whole thing seems like a nightmare though because of the current coating and the need to make sure the bushing holes and grease nipples don't get coated.
Old June 20th, 2011, 03:35 PM
roverx's Avatar
roverx
Scott Preston
Barry, totally understand if that is not the look for you. I would still suggest galvanizing and then a good paint. When the paint does chip as they all do you don't get the rust. My sliders are hot dipped and them painted with just Rust-oleum. Every few years I just touch them up and don't need to worry about rust. Even if you powdercoat over the galvy, it's still a better option them powdercoat along.
Best of luck
Scott Preston
carrier, tire, tire carrier
35" on Stock Rear Tire Carrier saber6 Misc. Chit-Chat 4 November 16th, 2005 09:45 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
