Tire carrier powdercoat - Page 2 - Defender Source
Old June 20th, 2011, 07:07 PM
CDeWan
Clay DeWan
5.3L beastie
Barry,
Maybe this is going to oversimplify it.
1. You can just tape off the bushings you don't want powder coated and the powder coat guys will know where you don't want it sprayed on. This also works if you shove so tape in the hole where you took out the grease fittings.
2. f the tape and when you get the carrier back, you get a brass brush that fits on a drill and just brush the powder coat off.
Not knocking anyone's suggestion, but I currently have the one you sold me at the powder coater and I just took blue painters tape and marked where I did not want them to spray. On my last tire carrier, I just cleaned off the powder coat that the idiots put on the brass bushings.
If you go through the trouble of popping your bushings out then the numbskulls will end up getting powder coat in the bushing hole and you will have to clean out the hole before you put the bushings back in.
2 cents.
Clay
Old June 20th, 2011, 07:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks Clay that makes sense
Would it also be a good idea to leave the grease nipples in?
Old June 20th, 2011, 07:59 PM
CDeWan
Clay DeWan
5.3L beastie
nipples
I wouldn't just from the fact that powder coating will kinda glue them in if you don't tape them off well. I think just take them out and roll up a thing of tape that fits nicely in the hole.
Old June 20th, 2011, 09:25 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Don't leave them in place. There are silicone plugs and special tape used to keep pc away. It's not a big deal and any good shop will know what to do.
Old June 20th, 2011, 10:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thank you. Much appreciated
Old June 21st, 2011, 12:03 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
You really need to remove the bushings / nipples and do a good job of getting it clean or when they put the carrier in the oven to heat the powder coating oil / grease will bubble out and cause defects in the PC.
Little defects lead to failure of the PC
Old June 21st, 2011, 12:44 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks Dave
I would assume the current coating has to be burned off and during this process all the contaminants would be removed?
Old June 21st, 2011, 12:53 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Sand blasting should be fine.
Old June 21st, 2011, 06:44 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Barry, this is sound advice ^^ ....do not leave anything in place. Remove everything. People that leave things in place are the same people who bitch about a lousy powder coat job 1 year later... just sayin.
What tree?
Old June 21st, 2011, 07:26 AM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
powder coating
All sound advice. I powder coat a lot of stuff. Remove the grease nipples and the bushings. Any oil and grease will be burned off prior to sand blasting. The powder coater should ask if any masking needs to be done and will do it for you properly. The oven is approx 400 degrees for 40 minutes.
Old June 21st, 2011, 08:54 AM
kevkon's Avatar
kevkon
kevin
I think it's a good idea to always keep in mind that powder coating is just another way to apply a finish to an object. Just like conventional painting, powder coating has a variety of formulas and they all have particular characteristics. And just like paint, powder coating requires the proper preparation.
So use the same criteria in choosing a powder coater that you would use in getting a conventional paint job.
Old June 21st, 2011, 10:36 AM
bjf's Avatar
bjf
barry f
94 ST #395
I do have fear of this coming out correctly. If you search and read about my experience with my 110 cage you will see why.
Old June 21st, 2011, 04:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Barry-
Interested in what direction you go with the spare tire carrrier. I was looking to replace my bushings as it rattles pretty good but the "might as well" button kicks in and and I am now thinking sand blast and a trip to the powder coaters would make it 100%
Question to anyone that has purchased a bushing kit: what is the difference between RN's and AB's beside the price?
http://www.roverparts.com/Parts/8987.cfm $59.95
http://www.roversnorth.com/store/p-6...fender-90.aspx $177.45
At $177.45, once you add sand blast (about $50) and then powder (about $100) you are not far off from a brand new Mantec unit.
Old June 21st, 2011, 04:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Mantec unit is for wagons not soft tops. As for bushings and bolts if you aren't going factory get them from mcmaster for much cheaper.
Old June 21st, 2011, 05:05 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
George at RDS has them for $5 each. The ones from AB certainly look sturdier, but if either gets the job done it shouldn't matter. I am interested to know which is better since I need these as well.
http://roversdownsouth.com/images/se...SERIES_HKS.JPG
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 21st, 2011, 05:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Those aren't tire carrier bolts. Those are for the door. Totally different. If you go genuine for the carrier bolts it will cost you roughly 225 for four bolts plus the cost of bushings. If you go mcmaster it will cost you 50 tops
Old June 21st, 2011, 06:01 PM
The bushings I got from mcmaster were just fine, but the bolts rusted almost immediately. Just FYI
Originally Posted by pendy
I'm here for the D's
Old June 21st, 2011, 06:17 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Blast your right. I was thinking the door. I need to do those too!
1995 Defender ST
1996 Discovery SE7
Old June 21st, 2011, 06:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
Second person who has said that to me. Why can't anyone find original style ones for cheap?
Old June 22nd, 2011, 07:58 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Barry,
I did this project recently. I had to have the bushings removed at a machine shop because they were seized. I got new shoulder screws from AB but the caps rusted quickly. I see that McMaster sells stainless shoulder screws; it would be worth investigating to see if they sell them in the proper sizes.
I had the carrier mediablasted and then powder coated. The powder coating has held up just fine. This isn't a high-impact area and I'm not worried about it chipping. If it chipped and rusted, I could always just have it re-done. You don't need to go full-Horsey here.
Pictures here: http://www.flickr.com/photos/defende...7624439349518/
carrier, tire, tire carrier
35" on Stock Rear Tire Carrier saber6 Misc. Chit-Chat 4 November 16th, 2005 09:45 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
