Tire Carrier bolts - Defender Source
Old March 18th, 2008, 01:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
Tire Carrier bolts
Is there anyway to get stainless bolts to replace the pivot bolts? There are four on the carrier. Three are the same size. One is longer.
Old March 18th, 2008, 04:54 PM
themaxx's Avatar
themaxx
Ade
94 ST
Have you checked with McMaster?
Old March 18th, 2008, 05:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
I haven't but I guess I should. Not sure of size. I think they are called shoulder bolts.
Old May 13th, 2008, 06:03 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Any success on finding the stainless pivot/shoulder bolts? I'm in the same situation. I just got a carrier and only one of the three is good. Rovers North wants $57.26...each! I'll mine the ore myself before I do that!
Also, anybody know how the pivot bolt in the photo is attached on the inside? I got the TC with it this way and it neither goes in nor comes out. It just wants to spin. RN's site shows an exploded view of the TC on page 60 of the catalog (part 34) and it looks different. Mine has no nut on the other end.
Pete
Old February 12th, 2009, 04:18 PM
whtd90
patrick james
has anyone found a cheap part to use other than oem LR bushings?
Old February 12th, 2009, 09:20 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I don't know if this shop would have these specific bolts but I did take them a box of all the rest of the bolts for the tire carrier and rear step bumper and they matched them all in SS for me. It was less then $20 and it took the guy there less then a day to fix me up with all the correct sized bolts.
The shop is here in Denver off of I-25 and Alameda.
http://www.aaametric.com/
Old February 12th, 2009, 09:25 PM
peachyracer
Peter Stolz
In my case, the old bushings were not great, but usable and I just made my own bolts by modifying off-the-shelf bolts. Sorry I don't have an answer for alternates for the OEM bushings.
Pete
Pete
Old February 13th, 2009, 10:10 AM
cabell's Avatar
cabell
Cabell Crowther
I believe Atlantic British has a reasonably priced bolt kit (non stainless). Check with Eric.
Old February 13th, 2009, 10:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
Let me know. I might be able to get a replacement set for you similiar to the type rovers north made.
Old February 13th, 2009, 10:57 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
McMaster-Carr part #
6659K34
Email:
Old March 10th, 2010, 10:00 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Ordered bolts from McMaster Carr based on comments in another thread. Seems they were not the correct thread. The original long bolt on my carrier is stripped so my plan is to re thread that part since the shoulder bolt has seems to be a bit larger.
The other issue I am having is that the bottoms of my brackets seem to be threaded. When I thread the old nuts on the new bolts they work, which makes me assume that I have the correct thread. I can't get the new bolts to thread the brackets first to even put nuts on them. Are the brackets supposed to be threaded on one side? Would the new powder coating on the brackets interfere with the threading of the bolts? Can I file down the threads on the brackets and just use the nuts to hold them together?
Alex
http://www.mcmaster.com/#90298a808/=65ocs1 Longer shoulder bolt
http://www.mcmaster.com/#90298a802/=65oda2 Shorter shoulder bolt
Old March 10th, 2010, 11:56 AM
1. yes
2. yes
3. no (use a tap to clean the threads out)
Old July 5th, 2010, 10:06 PM
Alex, did you tap the threads? Did the mcmaster bolts have the same thread and work?
I need a set of bolts for a tire carrier now too. I actually have a set from AB which looks like those mcmaster parts and at $60 it might actually be cheaper, but I don't want to press out/replace my bushings since the carrier will be galvanized later, and these seem to have a slightly larger diameter for the stock bushings and I don't want to force them.
Anyone have an old rusty set of bolts lying around? This is for my trailer and anything will do, even if just temporary until I tear it down for galvy.
TIA,
charles
Old July 6th, 2010, 09:33 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I had to have the carrier re blasted and coated because of some bubbles in the powder coat so I did have them tap the holes then. I ended up with new bushings since they pushed them out and I used some bolts from McMaster. I'll have to look at what I finally went with, I was given the correct part number from a board member. The ones I originally ordered were incorrect.
I have some extra (as in 20 something since they come in packs of 25 nuts) I can mail you if you are interested.
Old July 6th, 2010, 09:48 AM
So they tapped them out just to clear out the powder coat, not change the threads right? If that's the case, would you mind looking at your purchase history and let me know which bolts were the right fit? I have one stock bolt and nut so I don't need any for comparison (and I'm going to see if I can determine what thread it is at HD today), but if I do end up ordering bolts from mcmaster I might take you up on the offer as I'll need 3 then .
Old July 19th, 2010, 08:15 PM
Thought I'd post this here to help others out looking for this info. The hardware needed from McMaster is
1 x 92981A510 long bolt
3 x 92981A507 short bolt
1 x 93935A350 (you have to buy a pack of nuts)
8 x 6659K35 bushings
You can probably find them cheaper elsewhere but McMaster is great to deal with. See their site for dimensions which I verified against a replacement set from AB.
Old July 20th, 2010, 12:46 AM
bjf's Avatar
bjf
barry f
94 ST #395
thread the same on these? I know Alex had to send her's back.
Old July 20th, 2010, 01:50 AM
aosias's Avatar
aosias
Alexandra
1995 D90
These are the same as round 2 of bolts. The ones that work and are currently in use and look super duper.
Old January 9th, 2011, 11:49 PM
seriousactualist
Paul Martin
1995 D90 ST
Has anyone tried the McMaster shoulder bolts with the factory bushings with any success. The latter seem to be nowhere close to 16mm, and bolts manufactured within very fine tolerances tend not to fit.
-- Paul
Old January 10th, 2011, 12:10 AM
bjf's Avatar
bjf
barry f
94 ST #395
threads are different
bolts, carrier, tire, tire carrier
Rear Tire Carrier The Wizard Defender Technical Discussions 15 January 6th, 2006 11:29 AM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
