Tire Carrier bolts - Page 2 - Defender Source
Old January 10th, 2011, 11:09 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I bought the AB kit. Included everything needed to make the tire carrier good to go.
Old January 10th, 2011, 02:37 PM
seriousactualist
Paul Martin
1995 D90 ST
Thanks! I assume it's this kit right here, for anyone else who might be looking.
-- Paul
------ Follow up post added January 10th, 2011 11:44 AM ------
Originally Posted by bjf View Post
threads are different
Hrmmm. The McMaster specs for the shoulder bolts above in post 16 seem right (M12, 1.75). But the shoulder diameter tolerance seems too fine (much as my locally sourced bolts) to fit. I assume all would work well with these and new bushes. Or are you suggesting that something else is wrong here?
Thanks!
-- Paul
Old January 10th, 2011, 03:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
The thread pitch is different for the bolts that thread into the carrier. The one that goes through and has a nut on the end s fine.
Old January 10th, 2011, 03:56 PM
seriousactualist
Paul Martin
1995 D90 ST
Thanks, Barry. I double check mine when I get home.
-- Paul
Old January 10th, 2011, 04:13 PM
D90DRC
D Cantrell
1997 D90SW
Great Price R/N wanted 150 or so....
Still waiting for the Hope and Change to start
Old January 10th, 2011, 04:20 PM
97-D90-736
Nick Vogel
Think I paid 50 shipped for everything from AB. New Bushings, bolts, nuts.
Old January 16th, 2011, 10:09 AM
Paul, the thread pitches are fine, but I found the bolts to be a very tight fit with new bushings.
Originally Posted by pendy
I'm here for the D's
Old January 16th, 2011, 11:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
Alex bought the mcmaster set and the threads were different. I haven't seen it in person but maybe she can chime in.
Old January 16th, 2011, 11:49 AM
All I can tell you is I discussed this with Alex, bought the items and used them before posting my results here.
Old January 16th, 2011, 12:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
No clue. Just going on what she told me.
Old January 16th, 2011, 04:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just talked to Alex. Didn't realize she ever found the right part. Good to know. First set she ordered that were from a part number posted here were wrong.
Old June 5th, 2012, 11:39 AM
bjf's Avatar
bjf
barry f
94 ST #395
Posted this one other place.
Charles is it 6659k34 or 6659k35 for the bushings. I don't have my original ones anymore but it appears that if you use the 35 model it is a bit longer bushing and will block the grease port. If that is the size they used from the factory I guess it is no big deal.
Old June 5th, 2012, 11:58 AM
It's too far back to check my order history with mcmaster, but 6659K35 should be what I used.
Old January 10th, 2015, 01:20 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Old Post - but one of my many winter projects
I was sick of the rattling...so a retrofit of the OEM NAS rear tire carrier is one of my many winter projects. A few questions I wanted to float by folks who have done this:
1) Any tips re the best way to remove the old OEM Bronze Flanged Sleeve Bearings? I am thinking I am going to have to pull out the torch and try heat.
2) Re: the AB Spare Tire Hinge Replacement Kit
http://www.roverparts.com/Parts/8987
the longer bolt isnt the right size for my 94 tire carrier? Was this true for others? Does anyone have the contact info for the guy on the board from AB (is it Eric)?
3) Ill prob blast the carrier and bits, then POR 15 it. Any recommendations for a top coat? From my past experience POR does not hold up well to UV
This is a great thread for this project.
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old January 13th, 2015, 10:54 AM
Rufus's Avatar
Rufus
Rufus
Bump
Old January 13th, 2015, 01:57 PM
Easiest way to remove bronze bushings is to hit them with a chisel and a hammer (don't damage the steel, though.) It doesn't take much force to crack them into pieces because the material is quite brittle.
bolts, carrier, tire, tire carrier
Rear Tire Carrier The Wizard Defender Technical Discussions 15 January 6th, 2006 11:29 AM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
