Tire and Rim Advice - Defender Source
Old July 28th, 2007, 02:41 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Tire and Rim Advice
I have a 93 110 with an OME 2" lift that I want to put Tornado rims on. I have been told that I will have to use wheel spacers for those rims but I dont know if that is true or not. The new wheel set will be for street driving as the original wheels I will retain with the MT's(235/85/16). I am going to use BFG AT's on the new set and am thinking 285/75/16. Will the Tornado wheels stick out of the well very far or does the offset of the rim keep it in the well like the stock rim.
Thanks, Mike
Old July 28th, 2007, 10:50 PM
LRover's Avatar
LRover
J. Michael McCaig
You will need to use the spacers or remove the center wheel caps because of the kind of hubs you have on the 110 (The disc brake rear salisbury axle has the smaller hubs and don't need spacers). If I remember right, the offset with the Tornado rim and the stock 110 rim are the same, only the Tornado rim is a half inch wider. One more advantage; if you use the spacers to move the wheels out, the wider tires will be less likely to interfer with the radius arms in a tight turn.
tire
WANTED - 5 Spoke Alloy Rim jabber Wanted 1 March 2nd, 2008 06:57 PM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
37" MTR and Safari Gard rim tbmcneill For Sale - Parts 1 June 3rd, 2005 09:38 PM
WOlfe rim capatability rover4x4 Defender Technical Discussions 4 February 4th, 2005 09:55 AM
hard spare tire cover - will this fit a D90 rim? jaherring Defender Technical Discussions 2 October 11th, 2004 01:16 PM
