Tire Advice for ANR 4636 rims - Defender Source
Old May 11th, 2011, 11:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a set of ANR 4636 Series/1-ton rims that I am planning to put some mud terrains on. The spec on the steel rims says: 5.5F x 16 x 33. My current tires are a set of BFG AT T/A KO in size LT265/75/R16 on Toronado alloys.
I am trying to figure out if I can go up in tire size on these new rims without rubbing or having to put in spacers and I also want to make sure I have enough room for articulation on the trail without rubbing on the fenders. Not sure if it matters but I have HD OME in front and MD OME in rear which is supposed to give a little bit lift over stock.
I really like the tire choice and size on #410 here: http://www.eastcoastrover.com/149.html
Are those BFG MT's? What size are they?
Old May 12th, 2011, 12:36 AM
bjf's Avatar
bjf
barry f
94 ST #395
Km1 in what looks like 235 85 16 but I could be wrong. The 235s will fit your truck but I think the 265s are too big for the 5.5 rims. The nas 110 had 6.5 wheels
Old May 12th, 2011, 12:50 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ah, man. So these are the narrower of the steelies then? Are my Toronado rims 6.5" wide?
KM1 or KM2, is there a preference between the two?
Old May 12th, 2011, 01:09 AM
bjf's Avatar
bjf
barry f
94 ST #395
Your wheels are 7 actually. Km1s look better but on road are loud and wear badly. Good news is that you can't buy km1s anymore. Km2 or nothing. I have had two sets of km2s and they are actually really nice.
Old May 12th, 2011, 02:33 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by Manimal View Post
I have a set of ANR 4636 Series/1-ton rims that I am planning to put some mud terrains on. The spec on the steel rims says: 5.5F x 16 x 33. ?
1 ton/130/NAS110 were all 6.5" (same as the military "wolf" HD vented rim)
most alloys (LR factory ones for defender/disco1) were 7"
If yours says 5.5" then it's a "standard" 90/110 plain steel. you can squeeze a 235 onto them, but I wouldn't go any wider.
Old May 12th, 2011, 06:49 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yup, the ANR4636 is a late 109 wheel. 1 5/16" offset.
The tire manufacturer web site will tell you the minimum rim widths for their tires. I try not to go narrower by more than 1/2".
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 12th, 2011, 07:32 AM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
If I were you, I would look hard at 255/85 KM2. Does anyone have experience with this combination of wheel and tire?
Old May 12th, 2011, 09:17 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks for the education. Is there a performance downside to going to a narrower rim/tire? Less traction? Should I be looking for the 6.5" steel wheels instead?
Old May 12th, 2011, 09:38 AM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
Think of a contact patch on the ground. The larger the contact patch, the more traction you will have. A taller tire will allow for a longer contact patch. A wider tire will obviously provide a wider contact patch. It's a delicate balance between traction and going too wide where the truck ends up looking like a jeep (that's what I think, at least).
Old May 12th, 2011, 12:15 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Only if you ignore the coefficient of friction of the surface and the weight being applied.
Old May 12th, 2011, 01:40 PM
specops1526's Avatar
specops1526
Beluga '97 90
If you want, a set of the 6.5 wheels, I've got them for sale. I think I have 1 set left now.
http://www.defendersource.com/forum/...ad.php?t=30990
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 12th, 2011, 04:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks for the offer. What shape are they in? Dents? I picked up my set of 5.5's for $150 and they are pristine now that the paint and rust was chemically removed. No shipping since it was a local purchase. Hard to beat that price. I'm trying to figure out if it's worth it to shell out several hundreds more just to get a wider rim. That's why I was asking for opinions around rim/tire width.
Old May 12th, 2011, 05:07 PM
grnrvrs's Avatar
grnrvrs
Paul
88
ANR4636 is a tube type, right? Might be worth a few bucks to get a set of wider tubeless rims.
Old May 12th, 2011, 05:09 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Don't know. How can I tell? Are the 6.5's tubeless?
Old May 12th, 2011, 05:21 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Depends upon the rim. Some 6.5's are tube type and some are tubeless, e.g. ANR5593PM & ANR4583PM.
Old May 12th, 2011, 06:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Some people claim to run tubeless tires on ANR4636 rims (without tubes) with no issues. Personally I've never tried it.
I like 7.50Rx16 tires on Land Rovers and they will fit the ANR4636 fine. Assuming you can find any, they are fairly scarce in the US.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 12th, 2011, 07:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Who makes those?
Old May 12th, 2011, 08:29 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I'm running 7.5 16 Dunlop Radial Rover RTs. Love em, but can't find them anymore.
Old May 12th, 2011, 08:33 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
I believe John Lee from EE has michelins in xzl 8.25 r16 without tubes on those wheels
Old May 12th, 2011, 11:36 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I've had 235/85 BFG AT tires on those rims with no tubes and no issues for the past 6 years/40,000 miles. They're about worn out and am looking at the Cooper Discoverer 255/85. Actually, now that I think about it, my other truck also has the tire/wheel setup with no issues.
Chance
rims, tire
Need some advice on Nato rims ddrotts Defender Technical Discussions 12 August 12th, 2010 04:53 PM
Tire advice. ajh Defender Technical Discussions 21 July 16th, 2010 11:48 PM
Tubed and Tubeless rims Glenn_Guinto Defender Technical Discussions 25 March 28th, 2010 04:23 PM
What is biggest tire size I can get on stock rims? Birdman Defender Technical Discussions 10 November 21st, 2009 11:09 PM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
