Tips on Swapping out the T-Case input Gear? - Defender Source
Old April 23rd, 2009, 04:18 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey All,
I've had a cross drilled input gear for the LT230 in my '95 D-90 sitting in my garage for awhile. I'd like to get it put in before there are any issues. Any tips on the install (I know it can be done through the PTO cover)? Should I use a bearing puller and reuse the existing bearings (Since I can't really change the front race (can I?) or buy new bearings (anyone have the P/Ns if so)? I seem to recall hearing that it can be tough to mesh the new gear back up when installing it, and tips for this? Thanks in advance..
~Scott T.
'95 D-90 ST - AA Yellow
Old April 23rd, 2009, 04:50 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I just did the one on my RRC e-series LT230 and it was a piece of cake.
Yes, put new bearings on the new gear before the swap out, and swaping the rear race is not a big deal, I left the front in. I did not need a puller, just put the T-case in neutral and the gear comes right out and goes right back in as well. Easy smeezy job. The rear race is in the inner cover, no prob.
I did my stub shaft at the same time since it was a ZF 22, no more klonks, all gone.
Old April 23rd, 2009, 05:14 PM
Someone will remind us of whether a 2in output with mate with the new 3in input. I forget which way it works and which way it does not.
But yes, it is an easy job.
Input Gear Bearing P/N? LRNAD90 Defender Technical Discussions 3 April 25th, 2009 04:13 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Lt230rc redrover Misc. Chit-Chat 3 February 29th, 2004 09:09 PM
