Tips for removing Clutch Pressure Plate - Defender Source
Old June 29th, 2017, 12:01 PM
JehovahNissi77
Ceyon Woods
1991 200Tdi D110 CSW, Arles Blue
I know this should be simple and I've been searching but this step seems to get glossed over when trying to access the clutch. Thanks to this site. I was able to get the motor and trans separated.
It's my first clutch replacement, it took a bit to get to this point, removed way more parts than expected to get enough room between the transmission bell housing without removing the seat box or cross member (rusted in place).
Trying to remove the clutch pressure plate but it keeps spinning. Looking for a way to lock the flywheel so I can replace the clutch.
Also some of the studs came out of the bell housing when removing the nuts that bolt it to the transmission is this normal?
Trying to get back on the road this weekend, I've been down a couple of weeks and
1991 200Tdi D110 CSW, Arles Blue.
Old June 29th, 2017, 12:55 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
You didn't mention the engine, but it isn't hard to lock the flywheel with a screwdriver or piece of metal wedged into the ring gear to prevent the engine from turning.
When doing this sort of thing it is common that the whole stud and nut comes out.
I remove all the studs and replace them with bolts so it makes assembly much easier.
RDavisinVA
Old June 29th, 2017, 01:45 PM
JehovahNissi77
Ceyon Woods
Apologies! Its a 200tdi with an LT77,(with knackered 2nd gear SYNCHRO).
Thanks. I'll give the screwdriver a shot and see if Lowes has some suitable bolts. I noticed that one of the nuts was missing when I took off the Trans Cover, so I had to go there anyway.
Old June 29th, 2017, 01:52 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I think the bolts would need to be M10 1.5.
You can gauge the length by where the nut stopped on one of the studs that came out.
RDavisinVA
Old June 29th, 2017, 02:42 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
You may use a 27mm spanner on the central nut in front of the crankshaft to fix it.
You might need a setting die to fix a new pivot into the crankshaft and a tool to center the clutch disk while fixing the housing with the flywheel.
I prefer studs to fix parts whenever possible.
Old July 7th, 2017, 01:55 PM
JehovahNissi77
Ceyon Woods
Thanks for the tips. The Screwdriver worked out great and I got a clutch alignment tool from Rovers North. The real fun began when torqing down the blots. I snapped the head off. I went to Lowes to get a replacment and something to get the bolt out, found out later the thread pattern didn't match.
I then broke a drill bit trying to get the bolt out only to discover the remainder of the bolt moved rather freely. I used the dremel to cut a slot in it and the unscrwewed it with a flat head screw driver. All this rendered the screw extraction kit useless so my trip to Lowes was ultimately unfruitful but the bolts out. Ordering a replacement bolts from Rovers North.
I also discovered my clutch was not that bad, very rattly but lots of material left, which means the LT77 is most likely shot. Thanks to Uncle Doug's recommendation I ordered a stumpy R380 from ascctoft with all they had to offer including HD bearings and higher 5th gear. It should be shipped in a week.
This project snow balled quickly. I now need to drop the cross member to get the downpipe completely out as I chiseled it from the turbo to try to get more room between the transmission and motor while trying to drill the bolt out. I already had a new down pipe as the old one has a few holes. Rover North to the rescue again. The down pipe won't come out with the X member in place. I could cut it but I still have to get the new one in so I rather try to just the crossmember out. It appears to be welded in place by rust. My neighbor lent me a high lift so I'll try that and see how it goes. Oh I also broke my 13mm socket. I can't drive the 110 but I haven't been bored either. At this point I think the whole neighborhood is just as excited as I am to get the 110 rolling again.
Old July 7th, 2017, 02:03 PM
Naplm00
M
Use a bottle jack in between the left and right frame rails with some wood for support. Place the jack as close as you can to the Crossmember and then hammer it out of place.
Also, I know what's it's like to be "hard on the equipment" as a friend has recently said about me. Take a step back, get the tourqe settings for everything and stop gorilla wrenching. I have the same issue sometimes
Old July 7th, 2017, 03:33 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Great advice.
The cross member is press fit meaning the frame rails have to be pushed open to get it out.
Tight is tight and tighter is not better.
If you think everything has to be extra tight use the torque settings as recommended.
If you continue to over tighten parts, you'll destroy things like brake lines.
Over tightening does more harm than good!
For example: lets say you stretch your clutch bolts with too much torque.
Later when you are driving they will sheer off because you weakened them with your heavy handed over tightening.
RDavisinVA
clutch, vin
New Diesel Clutch & Pressure Plate LRover For Sale - Parts 0 April 24th, 2013 03:27 PM
Td5 clutch and pressure plate ECR Vendors 3 March 9th, 2011 04:20 PM
Clutch Pressure Plate Question bstraw Series Technical Discussions 4 November 30th, 2010 01:44 PM
Determine clutch pressure plate wear cgalpin Defender Technical Discussions 5 November 19th, 2010 06:14 AM
pressure plate jperakis Misc. Chit-Chat 1 April 27th, 2004 08:45 AM
