Tippy lifted Truck - Page 2 - Defender Source
Old May 22nd, 2009, 08:30 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I would also suggest that the front suspension is less likely to have as much down travel with stock arms even with slightly taller springs and longer travel shocks, so keeping the front sway bar to maintain road manners isn't much of a compromise.
At the rear, with the exisiting shocks and fitting taller springs, I would suggest relocating the upper shock mounts to recover the 2" of down travel "lost" with the taller spring, w/o the sway bar.
And, one can gain more brake hose travel by loosening the tee on the rear axle, straighten the mounting bracket, rotate the tee 90* and put it together. It can be done without losing any fluid.
Going to Rausch Creek Wednesday- want to go?
Email is
Same place, new dogs.
Old May 22nd, 2009, 09:27 AM
Rugbier's Avatar
Rugbier
Gustavo
Trevor, check your pm about RC
NO SIGNATURE
Old May 22nd, 2009, 09:39 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by rover4x4
All that rear does it limit the rear travel. I didnt even notice it was gone with stock springs. Just as well run no sways as to run no front.
Disagree. The rear is the one to keep as the radius design of the front already supplies some sway control. There are many other reasons why the back will work better, offroad as well. Feel free to do research.
I have a completely custom swaybar for go fast. It's on the back.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 22nd, 2009, 10:40 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Maybe something after market only on the rear. The stock job is too small to do squat alone in the rear.
Old May 22nd, 2009, 12:05 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by Treuwer
Gustavo, if you want to see how a soft top with no sways feels PM me. I'm close and I'll let you try out my set up to get a feel. I would ask if you could bring that 430 I saw a few threads back... but it's not necessary.
Rovertym 3" with Rancho 9000s, 35" BFG AT.
You are awesome. PM sent
NO SIGNATURE
Old May 22nd, 2009, 12:14 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If that's the case, which I suppose it could be, then the best thing to do is leave both on and disconnect the front when you wheel. If you wheel with the front only your making a bad situation worse.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 22nd, 2009, 02:10 PM
I know there is merit to this, and as far as suspension is considered youre light years away from the OME HD/MD setup.
FOR SALE: 1989 Land Rover Range Rover Classic (lifted) Rovercox For Sale - Vehicles 33 May 28th, 2014 09:44 PM
A Great Read... CDN90 Misc. Chit-Chat 6 December 16th, 2009 12:25 PM
Rookie question... How to determine if my truck is lifted or not. KKilo23 Defender Technical Discussions 31 July 6th, 2009 10:55 AM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
