timing specs - Defender Source
Old November 5th, 2013, 01:33 PM
wantone
Rick Thompson
94 ST #1222
timing specs
i found the idle timing specs for 6 +- 2 degrees, but what about full advance timing? you know where you rev the engine and the timing advances and check to see how far it advances, then re-check the idle advance? i know on other motors such as chevy's you can do this, and then adjust the timing curve in the dizzy if needed. any help would be great. thanks!
Old November 5th, 2013, 02:14 PM
I'd rummage round on the TVR sites .... this is the sort of thing they'd worry about on their tuned V8 plastic death traps.
Old November 5th, 2013, 04:58 PM
robertf
Robert F
1995 Discovery
This info is in RAVE
Old November 5th, 2013, 05:13 PM
wantone
Rick Thompson
94 ST #1222
awesome, i do believe i have that on my office computer! thanks!
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Why didn't anybody warn me timing chains are so annoying? Hans Misc. Chit-Chat 4 January 16th, 2005 11:40 PM
86 D90 Brakes, Specs? Larns Defender Technical Discussions 4 June 9th, 2004 06:55 AM
