Timing question - Defender Source
Old April 23rd, 2011, 01:05 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Timing question
My 3.9 RRC isn't running. I did a ghetto timing check by sticking a screwdriver into sparkplug hole #1 and hand cranked it to tdc. I took off the rotor cap and the rotor was between lead #1 and #8. Is this right? This would mean spark hits as cylinder #1 is coming to tdc.
I read the rotor should be 5 degrees advanced at tdc. So this in-between lead #1 & #8 should make sence right?
Old April 23rd, 2011, 04:13 PM
ini88's Avatar
ini88
Daniel Marcello
Never mind. I checked it on the defender and the timing is the same. Got the RRC started! Man it feels good to fix something that has been sitting for so long.
200 tdi timing question snowkistdynasty Defender Technical Discussions 4 December 23rd, 2010 11:32 AM
4.0 timing question bstraw Defender Technical Discussions 1 December 5th, 2008 08:07 PM
Dumb timing question sflash868 Defender Technical Discussions 4 October 1st, 2008 01:24 PM
Timing Question Grover Defender Technical Discussions 4 May 21st, 2008 06:58 PM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
