Timing Question - Defender Source
Old April 14th, 2008, 10:40 PM
Grover's Avatar
Grover
Question Timing Question
What are the timing graduations on the harmonic balancer on a 1995 D90 w/ 3.9L?
It looks like each graduation is 3 degrees.
12 deg. after TDC with 4 graduations and 12 deg. before TDC with 4 graduations.
Cheers...
Old May 19th, 2008, 06:31 PM
Grover's Avatar
Grover
Cheers...
yup...+/-12 deg with graduations of 3 degrees
Old May 21st, 2008, 04:26 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
You sure that's adjustable with the stock timing setup? I just swapped in a new timing chain and gears and my old setup wasn't adjustable. The new double roller was, but not the old one.
Old May 21st, 2008, 05:57 PM
???? He is talking about ignition timing, not camshaft timing.....
Old May 21st, 2008, 06:58 PM
Grover's Avatar
Grover
yup...ignition timing...
4.0 timing question bstraw Defender Technical Discussions 1 December 5th, 2008 08:07 PM
Dumb timing question sflash868 Defender Technical Discussions 4 October 1st, 2008 01:24 PM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
