Timing on a 3.9L - Defender Source
Old August 2nd, 2015, 10:02 PM
gwmckee
George
1994 NAS D90 #1919
Timing on a 3.9L
Hi Guys -
So I went to set the timing on my 94 D90 ST and was a bit confused. The manual says set the timing at 6 degrees BTDC. I located the markings on the harmonic balancer but am not sure how to decipher it. The marks show TDC and then there are five hash marks on with side with the two end points stamps "1/2"... one before TDC and the other after TDC. How do you translate that into degrees? When I put the timing light on my engine is actually way before the final 1/2 BTDC mark.
Thanks in advance!
Old August 2nd, 2015, 11:07 PM
Did you first set static timing to TDC? Do that then set the timing using the light with the engine running, vacuum advance disconnected.
I find it helps to put a dab of white paint on both the TDC Mark and the 6 degree mark.
Old August 3rd, 2015, 07:37 AM
gwmckee
George
1994 NAS D90 #1919
Thanks for the reply, Bill. That all makes sense to me and I did use the white paint trick. The challenge for me is figuring out which mark is six degrees. My markings show TDC then four hash marks on either side of TDC with the two outer hash marks marked "1/2". Nothing says 6 degrees. Is there some conversion I need to do?
Old August 3rd, 2015, 07:42 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
It's '12' not 'one half'.
Old August 3rd, 2015, 07:45 AM
There should be a clearly marked "BEFORE" and "AFTER" somewhere on the pulley. If I am not mistaken the hash marks are at 12 degrees, not 1/2. So somewhere right in between the outermost and zero you'll find 6 degrees.
Old August 3rd, 2015, 07:49 AM
nengelbrecht6's Avatar
nengelbrecht6
Nick Engelbrecht
2005 LR3 SE "No Name Yet"
As you are looking down on the balancer from the front of the Landy, to the right is BTDC and left is ATDC. Each hash mark is 3 degrees.
Nick
KM6FDZ
2005 LR3 SE
Old August 3rd, 2015, 09:13 AM
gwmckee
George
1994 NAS D90 #1919
Thanks Guys! It was the "12" not "1/2" that cleared it up for me
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Why didn't anybody warn me timing chains are so annoying? Hans Misc. Chit-Chat 4 January 16th, 2005 11:40 PM
