Timing Cover Gasket - Defender Source
Old December 24th, 2014, 10:42 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Timing Cover Gasket
Looking for best practices from the experts if different than what Rave calls for regarding using Right Stuff, RTV, or Hylomar on the timing cover gasket.
I see that some call for an additional Gasket maker, and that some do not. I have the aftermarket gasket with the bead of RTV on it; do/should I add more? Appreciate the help!
Old December 24th, 2014, 11:16 AM
I always use gasket compound. But be be very sparing with it as you don't want to block any ports or have little pieces spooge out that can fall off inside the engine and block a port or passage down the line somewhere.
Old December 24th, 2014, 11:53 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Great, thanks! Hylomar Blue ok? Both sides or one?
Old December 24th, 2014, 12:19 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
yes....one side...
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old December 24th, 2014, 11:28 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks fellas. Merry Christmas
Old December 25th, 2014, 12:05 AM
I wouldn't use RTV, but I usually use that Permatex Aviation Form-a-gasket stuff. That's what my LR techs I know use as well.
Old December 25th, 2014, 12:46 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
On the block or cover side?
Old December 25th, 2014, 10:39 AM
Both sides.
Old December 25th, 2014, 11:19 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks Jimmy. I bolted it back together but figure others can use this as a reference. FWIW, The consensus is:
No sealant whatsoever, use genuine gasket!
Hylomar on one side!
Permatex Aviation on both sides!
RTV on both sides!
RTV on one side!
Im glad for the choices...
Old December 25th, 2014, 11:53 AM
Basically it doesn't really matter.
Old December 25th, 2014, 11:56 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Recently used permatex anaerobic gasket maker for the RD oil pan. It was expensive but nice to know that any overage will remain fluid/won't harden and won't damage the engine.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old December 25th, 2014, 01:09 PM
Grover's Avatar
Grover
Thumbs up
RTV on both sides!
RTV on one side!
I'm a big fan of Hylomar. I used it on my upper intake manifold gasket on the coolant ports, no problems in the past eight years...
Did ROW 2.5 timing cover come from factory with silicone on gasket? ontheway Defender Technical Discussions 2 November 15th, 2012 12:45 PM
Valve Cover Gasket Tkleis Defender Technical Discussions 6 July 30th, 2012 04:48 PM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 12:23 PM
200tdi valve cover bolt gasket problems dave_lucas Defender Technical Discussions 15 November 16th, 2009 06:49 PM
Valve Cover Gasket and Tierod replacement bjf Defender Technical Discussions 3 February 10th, 2009 02:02 PM
