Timing Cover - Defender Source
Old July 3rd, 2008, 06:29 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Timing Cover
I have a 1995 3.9 to 4.6 conversion with the original timing cover with the integrated oil pump gears.
Can the timing cover be changed to the later serpentine type?
What is the advantage of the serpentine type?
Old July 3rd, 2008, 06:32 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
If you did a search, you would find that you could use a hybrid cover from a 94 - 95 disco.
Robert Deniro
Old July 3rd, 2008, 09:12 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
found that but didn't get any more details.....is that the name of it..."hybrid cover"?
is it in all those model years of discovery?
did you find there are advantages to getting it and having serpentine cover?
thanks for response.
Old July 3rd, 2008, 10:32 PM
94 and 95 discoveries and 95 RRCs.
Why you would do this I have no idea.
Old July 3rd, 2008, 11:16 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
that's what I was wondering.....is there a significant difference with the serpentine setup?
also, is the oil pump different (ie higher volume) or is it the same as the 3.9 pump in the cover?
Old July 4th, 2008, 11:38 PM
No reason to change. The in the cover oil pump has few advantages. If you are worried about pressure rebuilt the one you have. To switch over you need all new ancillaries and water pump, pulleys etc etc etc.
Old July 5th, 2008, 06:51 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
In addition to all the easy bolt on shite mentioned above, to convert an older shortnose crankshaft to serpentine you also need to machine the keyway on the end of the crankshaft longer by about 5/8".
Matt Browne
Old July 5th, 2008, 09:38 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
thanks....that's all great information. will keep it all original.
cover
Need to change front timing cover seals, auto trans flush... NY/NJ/MA/VT/CT area? KKilo23 Defender Technical Discussions 4 September 21st, 2009 03:35 PM
Hitch Mounted Cargo Carrier & Car Cover gamberik For Sale - Parts 5 January 5th, 2006 02:49 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
