Timing belt replacement help needed - Defender Source
Old April 13th, 2011, 01:41 PM
Whidbey's Avatar
Whidbey
86' 110
My timing belt broke on my 2.5 na diesel (12j). This is what I have so far. Bring the flywheel to the TDC position and lock. Bring the camshaft so the #1 piston is at TDC. Bring the injection pump sprocket to the timing mark. Install belt and new idler pully. Does this sound correct? How do I check to make sure camshaft is on correct stroke? Any advice would be greatly appreciated
Old April 13th, 2011, 02:04 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Here's the extract from the workshop manual for early and late 2.5's...
Old April 13th, 2011, 02:36 PM
Whidbey's Avatar
Whidbey
86' 110
Jaimie - thanks for the file. Hopefully I will be back on the road soon.
ac
300Tdi Timing belt failure and repair.. TDI Guy Defender Technical Discussions 46 November 11th, 2010 12:53 PM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 12:23 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
