time to remove and install soft top on d90? - Defender Source
Old December 16th, 2012, 03:55 PM
galileo
galileo
none
Hey guys im still shopping around for a d90 and heard that removing and installing is a PITA. Is this true? Please advise..
thanks
Old December 16th, 2012, 04:10 PM
Yeas, installing a ST in cold weather is a pain, you need to put in your garage with a heater and wait until it is good and pliable.
Old December 16th, 2012, 05:12 PM
Depends - original soft top with truck (if it's still even in one piece) yes - expect quite a bit of necessary patience in order to re-install it without ripping it. Badger top - takes me about 8 minutes to put on by myself - 10 minutes if I'm doing it for the Winter time (i.e. I take more time to make sure everything is tight). Fitting it to the windshield header bar is the biggest PITA because I have lights on the rollbar up there, but otherwise is fairly painless - the last little belt rail piece that is behind the tire carrier on the rear passenger side is the hardest part.
Really not enough effort to dismiss a ST.
90, d90, soft top, top
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Various Top Options Flagg Defender Technical Discussions 6 April 21st, 2006 07:19 AM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
