Time to de-rust the undercarriage - Defender Source
Old October 6th, 2013, 11:43 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok friends.. I'll be spending the fall/winter sipping beer and chipping away at my D90 to get her ready for the spring. Any suggestions with the rust/mud undercarriage? Wire brush and elbow grease? I own a power washer. Now a good idea for the loose stuff? I also own a sand blaster. Not a good idea? Back to wire brush and beer?
Old October 7th, 2013, 01:16 AM
How bad is it?
The major rust spots are behind the transmission crossmember and the rear crossmember.
The outside rust is less of a concern than rust from the inside out. I would powerwash the crap out of it, wire brush on an angle grinder, rust converter, primer, chassis paint and the. Waxoyl the inside and out.
Or just do a frame off and have the frame galvanized.
Old October 7th, 2013, 11:24 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Originally Posted by evilfij View Post
How bad is it?
Thanks for the great advice! I'm not sure how bad the rust is on the crossmembers. The rear one has a few holes that I was hoping to patch up (rather than a costly replacement). I'll dig in to see behind trannycrossmember.
Thanks again. I'll be chipping away all winter, a few hours/week. Wish me luck!
Old October 7th, 2013, 12:48 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Sounds like you are off to a good start. If your rear crossmember does have some rust holes, I would definitely recommend replacing it now. In the long run it will be an easier and a more permanent fix. At a very minimum, get the crossmember sand blasted inside and out and make sure it's not worse than you thought.
Old October 7th, 2013, 04:17 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I agree with Macker. By the way, if you have air tools, a needle scaler is great for getting into certain areas, and make sure you have a variety of brush sizes, shapes and rigidity to get into all the areas.
I stripped mine to metal, then used POR15 Prep & Ready, then POR 15, then a Flat Black Top Coat.
Rust stains on soft-top Rover- Girl Defender Technical Discussions 3 February 17th, 2006 01:12 PM
superficial rust on bolt heads 97 SW kevincdoyle Defender Technical Discussions 3 January 3rd, 2004 09:55 AM
Inconsistent post time bd90 Support & Suggestions 4 December 19th, 2003 08:34 AM
Door Frames That Don't Rust Out... TDI Guy Misc. Chit-Chat 6 December 8th, 2003 02:58 PM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
