Time for a new clutch...I think. - Defender Source
Old July 2nd, 2013, 10:36 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
As many of you have realized, any time you stop to work on your truck you'll discover three more things to do. After finally getting mine running this past weekend, I discovered that the clutch is slipping.
This truck is new to me too, and it's my first Defender so I'm trying to figure out what the possible problems are before I sit down and order parts.
First, I noticed that the clutch pedal has very "off or on" feel to it. When I press the clutch and slowly easy my foot up, it doesn't really lift up smoothly but then suddenly pops up. At first I thought it was a bad clutch pedal spring but replacing that didn't help. The upward travel of the clutch is not smooth/constant at all.
Then when driving it, I noticed that the friction point was almost at the very top of the pedal's travel. I also had a couple of rough gear shifts from first to second and to third. Didn't get past third very often on my test drive.
In reverse, The truck almost didn't want to move until, again, the clutch was nearly completely released. The truck also didn't pull away from stop very well despite having a strong engine. I felt the clutch slipping.
Question: will replacing the clutch also solve the feedback I'm mentioning with the clutch pedal? I expect the friction point to improve but I don't have a bench mark of where that point should be or how the clutch pedal should feel.
Could anything else be causing what I'm describing?
Thanks in advance.
Old July 3rd, 2013, 12:15 AM
Marks Landy's Avatar
Marks Landy
Mark
1985 90 CSW 200TDI
Have a look at your master cylinder, adjusting your bite point lower down is worth a try.
Old July 3rd, 2013, 03:17 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Thanks for the tips. As I've research the issue some more I've come across the proline vs genuine parts debate. I understand that proline is ok for non critical parts. I take it that clutch and pressure plate don't fall in this category. Anyone have any issues with proline parts for this application?
Clutch Problem Miller Defender Technical Discussions 3 September 3rd, 2012 12:46 PM
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
