Tightening front damper nut - Defender Source
Old September 6th, 2016, 02:40 PM
PJambo
Parker
1987 110
I've replaced the front dampers, but can only tighten the top nut into the stock turret so much before the whole damper starts spinning. It is tightened less than I'd like it to be.
The issue is that I can't get a solid handle on the upper portion of the damper while I tighten the nut. The upper portion doesn't peek out of the turret by much and the coil prevents me from threading my hand up into the turret. I could try a chain wrench, but it seems the only place to fit it is on the most delicate part of the damper. Am I missing something obvious?
I could replace turrets with tubular turrets, but trying to avoid that for now if someone has another solution.
Old September 6th, 2016, 02:46 PM
It depends on the brand, but there is usually something on the stud to put a wrench on and it is suitable for tightening the nut. It usually does not work for loosening, but okay for tightening.
If that is gone/missing, then water pump pliers are the best choice (https://en.wikipedia.org/wiki/Tongue-and-groove_pliers), IME. Be careful, as on most shocks, the upper part is just a thin mud shield.
Old September 6th, 2016, 02:54 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
It doesn't have 2 flat spots on the top of the shaft? Or an Allen head hole in the top? What shock brand?
Old September 6th, 2016, 04:34 PM
deanclean's Avatar
deanclean
Ryan Stevens
1995 Defender 300tdi
I just replaced mine yesterday. On the end that the two nuts go on there is a square tip. You can Put a crescent wrench on that tip or vice grips or whatever you want to get a grip then tighten the nut as much as you like. My issue was not knowing how tight to do it up
Old September 6th, 2016, 10:52 PM
PJambo
Parker
1987 110
Great, thanks all for the replies. My shocks do indeed have the square tip, and I was able to further tighten the top nuts. Thanks again for the help!
Old September 7th, 2016, 06:36 AM
deanclean's Avatar
deanclean
Ryan Stevens
Glad it worked out. I am very new to defenders (only had mine for two weeks or so) this is the first post I was actually able to help someone.
ht
WTB - Bilstein Front Shocks/Steering Damper for D-90 wadaman Wanted 0 April 23rd, 2009 08:17 AM
Steering box shaft movement after tightening pitman arm nut Neil McCauley Defender Technical Discussions 18 June 10th, 2008 01:18 PM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 03:16 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 07:31 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 07:55 PM
