Tie Rod/Track Rod joint removal....aarrrrghh - Defender Source
Old October 23rd, 2010, 12:51 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
When doing my brakes I noticed that one of my tie rod ends was in bad shape, so I ordered a new set figuring that I may as well replace all 3 while I'm at it. I searched the forum and got all the good info about measuring the rods/building a jig and/or counting threads. So now I'm all set to make this "easy" fix. Except for one thing:
How the H do I get the ball joints out of the tubes? I'm sensing the original install may have been in 1984 and taking a wild guess that anti-seize wasn't used. I'm pondering using C4, but I think that might mess things up down the road. My other option at this point involves a rope with a noose. Both would probably annoy the wife.
Any tricks to this?
Edited: The answer is carefully directed will-power. Moderator, you can delete this post.
Old October 23rd, 2010, 01:55 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Found a big ass pipe wrench I guess?
Old October 23rd, 2010, 02:32 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Pipe wrench + heat = loose
Old October 23rd, 2010, 04:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have had to heat them with a torch to unscrew in the past on some old trucks.. May be a good time to upgrade to HD rods while replacing the joints..
Legend in My Own Mind.
Old October 23rd, 2010, 06:20 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Some judicious use of a large hammer on the tube in the region where the joint screws into the tube shakes things loose pretty well. then put the rod in the vise and twist the joint with a large ring spannet hooked over the tapered section.
Mike Hammond
Old October 24th, 2010, 01:08 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Originally Posted by TDI Guy View Post
..May be a good time to upgrade to HD rods while replacing the joints..
I'm sure Rovertracks will see my $$ sooner rather than later, but I didn't think about this ahead of time. Fortunately now everything is anti-seized, so next time should be a cinch.
Anyone using the high clearance rod? Worth the extra $100?
Also - another question out of curiosity. One of the replacement ends (#RTC5870) that I got has a nipple on it, but my original did not. The other new one (#RTC5869) does not. Whats up with that?
ac, rack
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Bent Tie Rod kellymoe Defender Technical Discussions 19 August 27th, 2008 09:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
