Tie rod spins - Defender Source
Old January 12th, 2008, 05:27 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Tie rod spins
Putting everything back together after swapping in a new front axle housing, radius arms and doing a swivel ball rebuild on one side this afternoon and one of my tie rod ends spins when I try to tighten down the nyloc nut. Screwed aren't I? I have a couple of old tie rods with good ends around, hopefully they are the correct direction thread, this is a DAP HD rod and ends with one RH and one LH thread ends.
Old January 12th, 2008, 05:32 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
You might try an impact wrench that will spin it on fast!
CB
Old January 13th, 2008, 12:43 AM
kevin
In these cases I use a 2 x 4 wedged aganist some immovable object with the tie rod end as the fulcrum, pushing the tie rod end further into the eye. usually works, hope that makes sense.
also not a bad idea to make sure the threads aren't effed up.
rgrds
-dave
Old January 13th, 2008, 10:33 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Got it done. I just put a rod end puller on backwards and used a fat washer to protect the rod end, it tightened right down.
Old July 16th, 2008, 06:33 PM
GYM's Avatar
GYM
Gary
97 SW
Since there is already this existing post on tie rod ends...
Can someone help clarify a tie rod end part number? (NAS V8I Defender)
Is the tie rod end with CLOCKWISE threads p/n RTC5869 or RTC5870 ?
Am not near my truck to verify which side the clockwise thread end goes on.
Thanks very much.
Old July 17th, 2008, 10:59 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For future refrence, the easiest way I've found for those tie rod ends is use a normal nut, of the same thread of course, tighten it up, take it off then install the nylock.
Or by tie rod ends that use castelated nuts. I like them the best anyway as you can reuse the nuts.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 18th, 2008, 01:13 PM
yeah but you still have to replace the cotter pin.
i use whatver they send me
not that I would ever re-use a nylock *cough*
Old July 18th, 2008, 03:07 PM
If it spins it WILL pop out and you WILL die . . . . . (eventually).
Old July 18th, 2008, 03:22 PM
I've seen the results of not using the correct NEW hardware in critical applications. but I've also reused alot of nylocs on tie rod ends with no troubles in 13 years. Do look at them from time to time. They always look the same. Don't try this at home kiddos.
Old July 18th, 2008, 05:44 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Has anyone every tried these.......
http://www.bulletproofsteering.com/steeringsystems.html
Old October 1st, 2009, 05:33 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Originally Posted by nikojo
Interesting set up. I wonder how it works.
Old October 1st, 2009, 07:01 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Have them on my Disco... Wished I'd never done it on the drag link. Rod ends don't pivot nearly as far as Rover ends do.
Keith
Big, Red and ... aaa Red..
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Bent Tie Rod kellymoe Defender Technical Discussions 19 August 27th, 2008 09:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
