Tie Rod replacement - Defender Source
Old November 30th, 2007, 01:38 AM
ttrover's Avatar
ttrover
Thomas Taylor
1997/ Defender 90
Tie Rod replacement
Had my truck fixed and the mechanic person says that I need a new tie rod. I went on this forum and found some info but not exactly what I need. My question is do I replace the ends only or is there more to replace. The mechanic says that he can tighten the rod but one bump will knock it out. Any ideas? Thanks
Old November 30th, 2007, 07:22 AM
There is no way you would need a new one unless it was bent or the ends were hopelessly rusted in place (and the joints needed replacing). Its not exactly and expensive part, but the wheels need aligning after its replaced.
ac
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Bent Tie Rod kellymoe Defender Technical Discussions 19 August 27th, 2008 09:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
