Tie Rod End Replacement - Defender Source
Old July 15th, 2011, 12:38 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Does anyone know the tread direction on the passenger side vs. the driver side tie rod ends? BTW, advanced auto has tie rod ends with grease fittings for less than $20 each. I'm going that route vs. OEM replacements that dry out too quickly.
Clay
Old July 15th, 2011, 01:01 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Just saw that Stephen has greasable tie rod ends for 10 bucks..
http://www.safarihp.com/defender/def...g/rtc5870.html
-Ren Ching
Old July 15th, 2011, 01:06 PM
1of40's Avatar
1of40
1of40
Thanks, i'll give him a call.
Old July 15th, 2011, 01:12 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
As for the thread direction.... i'm sure there is a factory fitting 'side', but it depends if someone has taken it apart in the past.
Best bet is to loosen the lock clamp and give it a twist.
Old July 15th, 2011, 01:15 PM
1of40's Avatar
1of40
1of40
Ah, smart man. I'm actually running a HD track rod and drag link and therefore they could be flipped around. Thansk for the advice.
Old July 15th, 2011, 01:49 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I believe the old adage, "you get what you pay for". They cost a little more but I stick to Lemforder (part of Zf). Rovafarm sells them for $29, he ships USPS priority boxes so you get them quick & cheap!
As far as the threading, one side is reverse of the other. This allows the tow-in/out to be adjusted by turning the bar connecting them.
Old July 15th, 2011, 03:49 PM
1of40's Avatar
1of40
1of40
Thanks Dennis. I haven't figured out why Land Rover supplies parts that can't be more servicable and when I see something like this it makes sense to me to take a gamble. BTW, the tie rods I picked up from our local parts store look pretty stout. In addition to the grease fittings they also came with a boot which should protect as well. Its rare for me to find a local shop that has something i can use and even more so to find that there has been some thought in the design and follow-through. If they fail within 30k miles like the last OEM set I installed I'll know better next time.
Clay
Old July 15th, 2011, 04:18 PM
i have had no luck with Lemforder and won't install them again.
Old July 15th, 2011, 05:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Did they wear out too soon?
------ Follow up post added July 15th, 2011 02:58 PM ------
Clay
How's the condition of your pitman arm ball joint ? Mine was so shot (@130Kmiles), I could move the joint with my hand. I did put a grease fitting on the base plate of the kit.
Old July 15th, 2011, 07:09 PM
smob's Avatar
smob
Steve
My lemforders were bad after about 7k miles; coulda been a bad install on my part, but I doubt it. I'm going to give the Safariresto greased ones a shot - and if they last 10k miles, it'll be a victory.
-Ren Ching
Old July 15th, 2011, 10:48 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Right side should be RH thread and the left side LH thread
Land Rover 110
Old July 16th, 2011, 12:06 AM
TS888's Avatar
TS888
Tony Sims
1984 110
It really doesn't matter which end threads which way, as long as they are opposite.
Tony
1984 110 "Smokey" (sold)
Old July 16th, 2011, 04:26 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you don't like the Lemforder Trevor carries two other brands.
When I spoke with him a while back he said he was getting in some that were greasable and have castellated nuts, which is what I like best.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
ac
D2 tie rod end KevinNY For Sale - Parts 2 July 11th, 2011 10:05 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Tie Rod End options loykd Defender Technical Discussions 4 August 12th, 2006 02:53 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
