Tie Rod End options - Defender Source
Old August 12th, 2006, 09:12 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Tie Rod End options
I'm sure this is another naive question, but are there different types of tie rod ends that I can buy? I have a new (to me) Rockware track rod and want to replace the rod ends before I install. Sources to buy?
Old August 12th, 2006, 09:31 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I got mine from George at RDS--they are fine quality, great price. Make sure you know the current thread hand (left or right...).
Old August 12th, 2006, 11:37 AM
I got mine from DAP, they are grease able
Old August 12th, 2006, 02:30 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I curious about the greesable ones... but I chose RDS and kept it stock. I heard the greesable ones are not sealed as tightly. Has anyone tapped and put a grease nippel inthe LR ball joints?
On this topic... where can you purchase the ball joint removal tool featured in the manual? I have the forks which work fine but I worry about f#$ng up the boot every time.
Old August 12th, 2006, 02:53 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
First and foremost, when you install the ball joints, use anti-sieze on the taper. Second, when removing ball joints, I have never used a "special tool" nor do I use the forks (very, very rarely). I just pound on the side of the "hole" that the ball joint goes into--it pops right out. Sometimes I have to pound for 15 or 20 times, but it will come. On stuborn ones, I put a little out pressure on the ball joint and then tap/pound on it. I never hit the ball joint, I never hit the threaded portion. Since the ball joint is tapered, all you want to do is "vibrate" it loose. And pound only on the side of what the joint goes into. Now that I think about it, I don't think I have ever used a fork.
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Bent Tie Rod kellymoe Defender Technical Discussions 19 August 27th, 2008 09:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
