Tie rod end - metric or inch? - Defender Source
Old August 24th, 2004, 12:05 PM
byrdseye
Bruce Byrd
99 D1
I would like to find out the size of the thread on the Rover tie rods (the male end that threads into the rod , not the tapered stud) I have one out but none of my pitch guages seems to fit very well. Is it 18mm x 1.5 or 11/16 x 16 or what? Help a dummy out!!!!!!
thanks
Old August 25th, 2004, 11:31 AM
byrdseye
Bruce Byrd
99 D1
Smile Found the answer!
The stock rover tie rod is 11/16-16 which is an odd ball and makes it impossible to find weld in threaded plugs for DOM or 4130. Howerver, Moog part #'s ES150R & L are 3/4-16 with a taper that will fit the rover arms. Hope this is of some help for those contemplating making their own 1.5" DOM links.
bb
Old October 1st, 2009, 05:35 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
bb
Are you running this setup? If so, how's it working out for you?
Old October 1st, 2009, 06:57 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
The taper is not the same, LR Taper is 1:10 I belive the old GM is 1:7
Keith
Big, Red and ... aaa Red..
Bent Tie Rod kellymoe Defender Technical Discussions 19 August 27th, 2008 09:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod End options loykd Defender Technical Discussions 4 August 12th, 2006 02:53 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
