Tie Down Rings - Defender Source
Old June 15th, 2012, 10:24 AM
Tie Down Rings
Hey all, I bought I bought 2 bags of these tie down loops from Paddocks and they are awesome. I've installed them all over the the back of my 110 cargo area. Mud UK sells them too (about 20 GBP shipped for 6) and I intend to order another set to finish up the job. The install easily everwhere with an M8 bolt, and using a washer, you can mount them on your big side window inner trim bolts too. Adds a lot of versatility to load handling.
I haven't found these anywhere in the US, and sent a not to Lucky 8 recommending to stock them.
http://www.mudstuff.co.uk/shop/14-lo...own-loops.html
Old June 15th, 2012, 10:31 AM
While you may not find that exact thing here in the US, it is always a good idea to check with McMaster Carr first to see what they have.
Old June 15th, 2012, 10:37 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Those dont rattle? I installed some of these on mine - used bigger washers on the back side and they are very very solid.
Here's some kinda like the style you're looking for http://www.etrailer.com/dept-pg-Trai...pm-Brophy.aspx
Did some more searching http://www.mcmaster.com/#tie-down-anchors/=hzlfl9
Old June 15th, 2012, 12:09 PM
I've seen all those and McMaster didn't have anything like these. What I like about these is that they are single bolt. That's what's hard to find here. Makes it easy to use the existing bolts that are all over your interior and add cargo points. All of those mcmaster ones require multiple fasteners per tie down.
And no, I have 16 of these right now all over my rear, and none of them make a sound.
Old June 15th, 2012, 12:36 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
search part number 3076T13 - they have a single hole
Old June 15th, 2012, 12:54 PM
Good find!
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
WTT: Tie Down Rings for Lug Nut fleabus For Sale - Parts 2 April 16th, 2006 01:35 AM
Military J.A.T.E. Rings --->D90 norros For Sale - Parts 3 October 8th, 2004 03:22 PM
Trick tie rods skool Defender Technical Discussions 6 March 22nd, 2004 02:06 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
