Ticking noise. Oil pump? - Defender Source
Old September 27th, 2009, 09:50 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I started getting a ticking noise a little bit ago. Its in the engine bay and seems to be passenger side. Its not exhaust because i felt around and didn't feel air and it is more mechanical sounding than air an escaping noise. It ticks after the engine is running at normal temp. Im running thin 5-30 oil when I usually run thick 20-50. could the oil pump be making this noise? oil light is not on.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 27th, 2009, 10:01 PM
rocker shaft, lifter are more likely
Old September 27th, 2009, 10:08 PM
ini88's Avatar
ini88
Daniel Marcello
danmit! I was thinking a lifter or sticky valve too. I put some valve cleaner stuff in the engine and obviously it didn't work, but my hopes on a bottle of magic were low to begin with.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 28th, 2009, 10:59 AM
Take off the valve cover, you can probably figure out which rocker it is. Lifters chug at start up, rockers tick in my experience.
Old September 28th, 2009, 03:29 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Mine has developed a similar ticking. How difficult is it to replace rockers?
Old September 28th, 2009, 03:39 PM
Very easy to do. 15 minutes for passenger side, half-hour tops on the driver's side (pretty sure you have to pull the intake cover for that but you might be able to get the valve cover off without pulling it).
Old September 28th, 2009, 03:45 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Personally, I would not run 5 wt oil, my engine likes 10-15 wt. Change the oil, I will bet that the ticking goes away.
Old September 28th, 2009, 04:24 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Mine runs 20-50 dino oil... I need to check the exhaust to rule that out. I haven't had much time lately to tinker but maybe I can get back in the garage to check things out soon.
Old September 28th, 2009, 04:31 PM
I take the opposite tack. I use 0w40 or 5w40 synthetic. Rocker wear is usually caused by build up and or poor oiling from too heavy of an oil/and/or running low on oil and/or lack of changes.
Old September 28th, 2009, 04:40 PM
landrovered
S. Smith
I run synthetic as well but since I was not the owner for the first 80k miles of my 110s career, I use 10-40 Mobile 1 extended in my motor and since my RRC has 220k miles I run 10-50 Mobile 1 synthetic in it.
It has been my experience that lower weight oils like 0 & 5 will cause valve ticking in rover V8s.
Old September 28th, 2009, 04:47 PM
ini88's Avatar
ini88
Daniel Marcello
I use a 5-30 Mobil 1 in the winter and a 20-50 Amsoil in the summer. I changed the oil to 5-30 before I did a long drive up to Nova Scotia and back and since then I noticed the ticking. going to change the oil to the thick shit tonight and see how it goes.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 25th, 2009, 07:12 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
How did you make out with the tick?
Ticking noise at idle thug1313 Defender Technical Discussions 11 March 10th, 2005 11:20 AM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
Priming Oil Pump chrism Defender Technical Discussions 3 April 29th, 2004 03:53 PM
