Ticking noise from steering columb or dash... - Defender Source
Old June 19th, 2013, 02:16 AM
Drjeggle
Rudi
2011 Defender Puma
Hi guys.
I've had my Defender Puma since 2011. I had quite a few issues with it which have now been solved but I've always noticed a ticking noise coming from the dash or steering columb. It comes and goes. This morning when I turned my key in the ignition to heat the coils, it was really loud, louder than it's been. It made the noise for the entire drive to work. When I got to work, it kept ticking even after the key had been removed.
Please, if anyone has any idea what this noise might be, please let me know!
Thanks!
Old June 19th, 2013, 04:38 AM
Bad relay jumps to mind
Turn signals on!
Old June 19th, 2013, 04:52 AM
Drjeggle
Rudi
2011 Defender Puma
I don't think it has anything to do with my turning signal... Not sure what you meant there...? Bad relay, is that an easy fix?
Old June 19th, 2013, 06:28 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Since this happened when you had just powered things up I would also suspect a relay. You may have a few relays behind the gauge pack. (Like the older Defenders) If you can get your hand on them you can feel which one is causing the problem. They just plug in and then pull out, easy to replace.
dash
Steering box noise jayz Defender Technical Discussions 1 July 22nd, 2012 04:19 PM
Wheel arches (spats) Steering wheel dash parts tomaco1 For Sale - Parts 6 April 10th, 2012 12:50 AM
Ticking noise. Oil pump? ini88 Defender Technical Discussions 11 November 25th, 2009 07:12 PM
White noise type sound from steering wheel aosias Defender Technical Discussions 1 January 31st, 2009 01:47 AM
Ticking noise at idle thug1313 Defender Technical Discussions 11 March 10th, 2005 11:20 AM
