tick tick tick - coming from the behind the gauge pod - Defender Source
Old June 28th, 2011, 12:23 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
I get a very rapid, intermittent, and only slightly audible (over the sweet hum of a 200TDI) eletricky-sounding "ticktickticktick" when the engine is on, vehicle is in gear, and the accelerator is depressed. This does not happen while idling. It's definitely coming from the behind the gauges. I feel like it has to be something with the speedo cable given when it makes the sound versus when it does not. Can't see why anything else back there would sound off only when I'm accelerating.
Any ideas?
Initiative comes to thems that wait.
Old June 28th, 2011, 12:31 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Not very familiar with the 200tdi, but it doesn't sound like an exhaust leak, dear brother?
Old June 28th, 2011, 02:28 PM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
My speedo clicked before it kicked. easy'ish fix though.
Old June 28th, 2011, 03:34 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
no me brother, does not sound like an exhaust leak. seanh, when you say easy fix, presumably meaning replacing the speedo itself with a VDO or OEM, yes? that is an easy fix, perhaps the test would be to simply unplug the filthy old bastard and see if the tickticktick stops a ticking before i spend up for a new VDO.
Old June 28th, 2011, 03:54 PM
cellulararrest
Chris Snyder
If it is coming from behind the binnacle, which it sounds like you're sure of, that's the only thing I can think of that would be affected by acceleration or speed in anyway. A relay clicking wouldn't happen only on acceleration I wouldn't think.
edit: referencing speedo
Old June 28th, 2011, 06:16 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
I agree with the speedo diagnosis--I had the same experience as Seanh. In my case, the needle would bounce around a bit in addition to the clicking before biting the dust completely.
Old June 28th, 2011, 06:41 PM
google wibbly wobbly speedo
Old June 28th, 2011, 08:09 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Mine did the same thing. It is the spedo cable or gear in the spedo. Take the connector off the rear of the spedo, spray d40 or lithium grease into the cable. This should determine if it is the cable. It might stop the noise for a while but it will most likely come back. If you fit a new cable your done.
Land Rover 110
Old June 28th, 2011, 09:51 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Excellent - thanks for confirmation of problem area and the trouble-shooting idea -
Old July 14th, 2011, 03:40 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
tickticktick - lithium grease did the trick. many thanks
Old July 15th, 2011, 12:30 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Replace the upper cable...the grease is only a band-aid.
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Gas Gauge fried alaskajgg Defender Technical Discussions 0 April 4th, 2005 11:38 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
