Thrust angle - Defender Source
Old June 10th, 2008, 10:04 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Thrust angle
Could a -0.14 thrust angle (rear axle) make a truetrac (on both axles) pull left?
just checking
Old June 10th, 2008, 10:54 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
thrust angle meaning one wheel is .14 behind the other side? .14 degree? no way. or.14 inch? Highly doubt it. an eigth of an inch over 6 feet? seems so small that backlash/tire scrub would negate any difference that small
truetrac.. how do you like 'em?? ive been thinking of one or two.
~Steve
Old June 10th, 2008, 11:26 AM
D90user's Avatar
D90user
steve
degrees...sorry
The rear axle is pointing slightly towards the passenger side... slightly.
As far as the TT's go. So far so good, except they do make your little alignment problems come to light which is good. I have not had the truck on the road much since I put them in.
My truck is set up for travel so, to each his own. They are simple (muy importante), stronger and provide better traction than stock.
I did have them in the snow for a bit, they did not handle funny at all. Best choice for me.
ARB approach angle vs. stock sflash868 Defender Technical Discussions 14 April 1st, 2008 01:16 PM
Stereo Angle...a problem? D90user Defender Technical Discussions 12 February 17th, 2008 11:14 PM
rear pinion angle correction KevinNY Defender Technical Discussions 11 April 6th, 2007 03:35 PM
Center Diff Thrust Washers Paul Grant Wanted 2 December 21st, 2005 08:14 AM
front pinion angle ?? TDI Guy Defender Technical Discussions 8 April 11th, 2005 08:44 PM
