Throw out or input shaft bearing? - Defender Source
Old October 28th, 2012, 12:32 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Or something else? Just got back from a trip to the Panamints and the truck drove like a champ, as usual. Pulled up to the gas station in Mojave and when I came to a stop in idle out of gear it sounds like a midget with a ball banging away under my feet keeping time with the motor. I didnt drive back through Trona so I didnt pick up any trolls. Only hear the sound when I sit at idle.
Old October 28th, 2012, 12:35 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
If it sounds like small rocks in a coffee can, it is your cat(s). Down on power, even slightly?
Old October 28th, 2012, 12:40 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Not the cats, I dont have them on my truck, shhh. I am thinking input bearing. I have a lt85 . I dont feel up to taking this on myself so I guess I'll look for a mechanic in my area. Thanks.
Old October 28th, 2012, 01:07 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
What happens then you engauge the clutch? Put it in gear with clutch in?
-Jeff
The knocking goes away. Engages into first gear easily, maybe a little noisy driving from a stop but not knocking noisy, just kind of a louder gear noise than normal.
Old October 28th, 2012, 01:24 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
It might be still be clutch related, pilot bushing, pressure plate etc.
-Jeff
It could be, I was under the truck before the trip hitting all the grease fittings and thinking I have been neglecting normal up keep. I will look into that. I appreciate your thoughts on this. Thanks.
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
