Throw out bearing staple, are we suppost to glue it in? - Defender Source
Old August 31st, 2010, 07:34 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Throw out bearing staple, are we suppost to glue it in?
I hear that sometimes the staple can come out and I think that might have happened on mine.....mabye. Course the only way I'll know is after I bleed the clutch slave (just in case) and if the TO bearing still makes noise I think I'll just seperate the tranny.....again Anyway just wondering what would happen if we glued the staple into the TO bearing and the fork?
Robert Deniro
Old August 31st, 2010, 09:04 PM
The staple is not required. It can be removed during installation. Throwout bearing are not pulled back. The pressure plate pushes them back.
Throwout bearing noise versus other noises are pretty hard to isolate.
Old August 31st, 2010, 09:17 PM
The staples don't last well do to heat cooking the plastic. I just use a rubber band. The first time you depress the clutch pedal it cuts the rubber band. I think glue or silicone would be a bad idea.
Neil McCauley
Neil McCauley
Hmm, knowing my luck i gotta put on another clutch master/slave....again....and another clutch/plate/TO So what is the staple for, to keep the fork/TO together during installation?
Robert Deniro
Old August 31st, 2010, 09:21 PM
exactly
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
