Throw Out Bearing Fork - Defender Source
Old January 28th, 2012, 10:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
The clutch is beginning to slip in my 90. When I replace it should I get a heavy duty throw out bearing fork? I know nothing about this crap but it was suggested by another board member.
Old January 28th, 2012, 11:22 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
If I'm not mistaken, the clutch fork on the v8 is cast iron, as opposed to the rather thin one found on 4 cylinders/tdi's. So If yours isn't showing any signs of wear, then it's probably ok.
Old January 29th, 2012, 12:48 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
The clutch fork is part of the tranny so why would that be different V8 versus TdI??
Would think it would be the same unless the NAS tranny is different than ROW.
No???
Old January 29th, 2012, 08:52 AM
I got the run around on the clutch about 5 years ago. 3k later it was the little rubber flex hose between the bulkhead slave cylinder had gotten weak. I would think one of the clutches should last a very very long time if driven accordingly.. It would be worth a try if you havent already replaced it.
Old January 29th, 2012, 09:38 AM
Naplm00
Matthew
No???
Oddly enough they are different. All 4cyl gas and diesel use the stamped steel, v8s use the cast. Not sure if the TO bearing is the same tho
Old January 29th, 2012, 03:06 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Matt........that's great information.
I wonder if the cast fork can be swapped in for the stamped fork or if there are differences, ie the TOB, etc.
Good thread with pioneering information.......ha!
Old January 29th, 2012, 03:07 PM
Make sure it is really the clutch, not bad hydraulics. You must drive it hard as the clutch should last forever.
Old January 29th, 2012, 04:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
I dont drive hard at all. My last car I got 160k out of the clutch. It only slips right now in 5th which I was told is the first sign of it going. I only have 69000 miles.
Old January 29th, 2012, 05:37 PM
check the hose and the adjustment in the pedal box.
Old January 29th, 2012, 05:39 PM
Now. V8 and diesel bellhousings and the throwout assemblies are different.
Old January 29th, 2012, 05:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
Which hose and adjustment?
Old January 29th, 2012, 06:08 PM
Read the manual?
Old January 29th, 2012, 07:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by Red90
Read the manual?
Why would I want to do that
Old January 29th, 2012, 07:50 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yes get the HD fork. You will never have to worry about it again.
Land Rover 110
Throw out bearing staple, are we suppost to glue it in? Neil McCauley Defender Technical Discussions 4 August 31st, 2010 09:21 PM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
