Throttle Position Sensor Source?? - Page 2 - Defender Source
Old June 4th, 2012, 10:41 PM
Originally Posted by neilcouvillion
I am relatively new to this forum but would love some information, I am looking for a TPS for a 95 D-90. I am pretty sure it has the flat plug. Anyone know of a good source? I would however like a new one b/c I'd rather not go through the same problem if I get a used one.
Thanks in advance.
Neil
I got my last one from Atlantic British ... Actually mine wasn't faulty at all ... And I wasted my money. What makes you think yours is at fault?
Old June 5th, 2012, 12:15 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Will Tillery can get you a good used one. As far as I can tell, a new one is unobtanium. Buy two used ones from Will and keep one as a spare.
Old June 5th, 2012, 07:08 AM
neilcouvillion's Avatar
neilcouvillion
Neil
White 95 Defender 90 SW #230
My mechanic has been testing my truck on and off for about a month and is now 100% certain that it is the TPS. (fortunately he is a good family friend and hasn't charged me a thing) I called Atlantic British and they do not have any in stock for a 95, neither does Rovers North. Any problems with a non-stock TPS from Advanced Auto Parts? Do you recall if the 95 TPS is a flat or round plug?
How can I get in touch with Will Tillery?
Thanks.
Old June 5th, 2012, 07:21 AM
Thanks.
It takes 5 mins to properly test a TPS. Basically you put a multi meter and measure the voltage while moving the throttle to 100%.
Download this document and have your mechanic do to a fact based diagnosis.
http://p38arover.com/rover/p38a/Engi...UX_Systems.pdf
Old June 5th, 2012, 07:51 AM
neilcouvillion
Neil
The problem was intermittent, so catching it was the tough thing. He is certain that it is the TPS, but I will pass that on and have him look at this prior to ordering anything.
Thanks again.
What did your problem end up being?
Old June 5th, 2012, 08:00 AM
Thanks again.
TPS problems would be regular as its a potentiometer and occasionally they wear out in a particular region of the sweep ... You'd see this every single time you moved it past that position if you test it with a meter.
My problem was excess fueling caused by the throttle linkage being incorrectly set. THe TPS value was too high at closed throttle. Fixed in 2 mins but caused a lot of head scratching and money wasted on parts I didn't need.
What's you symptoms?
Old June 5th, 2012, 10:12 AM
neilcouvillion
Neil
My problem was that my engine feels like it cuts off and then comes right back on, a surge type feeling. This occurred between 1st, 2nd and 3rd gear. Sometimes in 3rd or 4th, I could push the gas to the floor and get no response. I never got a check engine light. It usually took place after engine was warmed up. This weekend, I had idle problems and it would go down to about 2-300 rpm and run sputtery. It actually shut off twice this weekend, which is the first time that had happened. And as I mentioned, it didn't happen every time, just every now and then
Neil
Old June 5th, 2012, 11:20 AM
Neil
Sounds like leaky air hose to me ... The plenum hose works loose I would check that..
Old June 5th, 2012, 11:58 AM
Or pinhole leaks even.
Originally Posted by pendy
I'm here for the D's
Old June 5th, 2012, 12:29 PM
I need the flat connector looks kind of like a weatherlock connector TPS if anyone has a hook up for a new one.
Old June 5th, 2012, 02:14 PM
squirt carb cleaner on the hoses when its running and it should drop revs if a leak pulls in the carb cleaner. This would help locate a leaky hose.
------ Follow up post added June 5th, 2012 02:22 PM ------
Neil
Forgot to say what a great looking stylish truck you have ... The white 95 SW is appreciated by the finest individuals who exhibit impeacble taste!
Old April 10th, 2013, 08:42 PM
jijalicious
Jiman Khosravan
'94 D90
Old thread.. but it is what i need.. so...
anyone have a tps for a 94 d90 3.9L ?
~Ji
Old April 10th, 2013, 08:50 PM
chris snell
Chris Snell
87 Ex-MOD 110
Will Tillery.
Old April 10th, 2013, 08:57 PM
jijalicious
Jiman Khosravan
'94 D90
Emailed him.. thanks.
Old April 10th, 2013, 09:56 PM
i have one if that doesn't work out
sensor
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
