Throttle issues - Defender Source
Old March 22nd, 2014, 12:42 PM
redway77's Avatar
redway77
Beatrix
110
Throttle issues
So this morning I start the truck to take it into town to get plants for my yard. Loaded up the kids the truck started fine. Rolled backwards out of the drive way then noticed the gas peddle does not work it's not stuck it just does not do anything when pressed. Truck went into reverse fine and into first gear fine. And lucky for me it's made it back up the hill into my drive way by just letting the clutch out half way. And the check engine light is on. Could this be a throttle assembly issue?
Old March 22nd, 2014, 02:09 PM
Did you take a look at the pedal or throttle assembly at all?
You have to give more info than hey guys something random is wrong with my truck ....
Old March 22nd, 2014, 04:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What kind of motor Beatrix?
With the motor off, just have someone push down a few times on the gas pedal while you're looking at the motor to see if the cable/springy thing moves.
Tell us what you find.
Rent my
Old March 22nd, 2014, 05:04 PM
redway77's Avatar
redway77
Beatrix
110
Thanks for the replies, I'm going to see what I can find. I'm going to have to wait till my father in law can help me push it into the garage.
Old March 23rd, 2014, 12:13 PM
redway77's Avatar
redway77
Beatrix
110
Well it's working fine now. Odd but again this could just be my rovers personality acting out.
Old March 23rd, 2014, 12:16 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Which engine? Last thing you'd want is a linkage issue that let's you open the throttle and then have it not close.....
Email is
Same place, new dogs.
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
D90 throttle pedal assembly and throttle cables Willard For Sale - Parts 2 October 14th, 2008 10:31 AM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
Off-Throttle Clunk... P1CR Defender Technical Discussions 2 April 7th, 2004 03:20 AM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
