Throttle/gas pedal cable - Defender Source
Old October 14th, 2008, 06:02 AM
dfscott
Daryl Scott
1994 Defender
Where might I lube the throttle cable on my 94 d90 that connects to the carburetor from the gas pedal? My gas pedal feels "tight" as if the cable needs lubrication or replacement. I tried penatrating oil at a place above the pedal but I can't seem to find a good point at which to lubricate the cable. Near the carb, the cable is wraped in rubber. I can't remember if the cable "opens" below the carb.
Alternatively, is it difficult to replace the cable? Difficult as in replacement without without a lift or fingers the size of a three year old? Thanks. Daryl
Old October 14th, 2008, 07:22 AM
Its probably best to get some lithium grease in a spray can, and shoot it down from the speedo end. I'm not sure how far it will get. Everything is a little more sealed up from the engine side. The cable is easy to replace if you are convinced that is your trouble, but before you go replacing or even greasing, make sure your cable isnt kinked somewhere and that its not getting hung up on your floor mats or something.
And not to be picky, but the cable terminates near the throttle body, not a carb - your fuel injected 94 doesn't have carbs.
Old October 15th, 2008, 12:21 PM
dfscott
Daryl Scott
1994 Defender
thanks Jim.....and your carb/fuel injector comment was helpful, not picky....
Old October 15th, 2008, 01:56 PM
Given the safety issues involved, I would just replace it.
Also, make sure it is not the pedal assembly itself that is sticking.
gas
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
