Threads, hoses, and fittings sizes - Defender Source
Old September 5th, 2014, 01:41 PM
I hope to have this become a library of information with others adding more as we go.
Just to get things rolling:
Brakes:
lines are 3/16th coated steel
Fittings are 10mm x1 with DIN (bubble) flare on male nuts and SAE (double) flare on female nuts.
T fittings are 10mm female
Master Cylinder nuts are 10mm and 12mm DIN flare
Master cylinder booster hose 1/2" ID
Master cylinder booster nuts M8
Tdi Turbo:
Fresh air intake OD 60mm or 2 3/8"
Boosted air outlet 2" or 50MM
Turbo piping 2" or 50MM
Exhaust 2 1/4 3 bolt flange or 2 1/4" OD pipe stub
Exhaust studs M10
Boost pressure hose ID 1/4" barb fitting with spring clips
Waste gate actuator pin 1/4" diameter w 3/16 E clip
Waste gate actuator mount screws M4 x 10mm
Old September 5th, 2014, 02:22 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Exhaust stud nuts = M10x1.5 prevailing torque lock nut, for Tdi's that is
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 11th, 2014, 06:14 AM
Just switched out the spillway rubber hose with 3mm ID clear silicone from McMaster-Carr.
Clips and Misc fittings source o2batsea Misc. Chit-Chat 0 January 16th, 2014 09:52 AM
ARB air line and two solennoids and fittings evilfij Wanted 8 September 19th, 2013 12:43 AM
Trim fittings (headliner and door cards) Chris Velardi Defender Technical Discussions 9 March 5th, 2012 10:28 AM
Fuel filter banjo bolts and fittings El Solis Defender Technical Discussions 9 March 5th, 2012 12:11 AM
What sizes and threads metric bolts are on a NAS Defender evilfij Defender Technical Discussions 11 March 25th, 2009 04:35 PM
