Thread size for temp sender - Defender Source
Old June 10th, 2004, 10:51 AM
mgrgpg
Mark
1989 D110
Does anyone know what the thread size is for the OEM temp sender?...I am replacing my temp gauge with a VDO and need a bushing to make the VDO sender fit.
Mark
Old June 10th, 2004, 11:31 AM
Abrooks's Avatar
Abrooks
Tony Brooks
This has been discussed elsewhere quite a bit. To make a long story short, I put one in the RRC, couldn't find any sort of bushing that would fit the British threading, wound up cobbling together pieces at Home Depot and stuck it into the heater supply line. Works perfectly, may have to do it to the 90.
Old July 1st, 2004, 08:41 AM
mgrgpg
Mark
1989 D110
If anyone is interested the tread size of the stock sender on my 94 is 5/8-18.
I ended up making a bushing myself, since there are no bushings that go from straight treads to pipe threads. The VDO sender is a 1/8" pipe thread. I was actually able to fit the VDO sender inside the bushing and now it sits in almost the same position as the original.
Thanks for the help,
Mark
Old July 1st, 2004, 12:00 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Mark
Good question. I was in the process of doing this myself. A friend of mine had already installed a VDO sender in his 95 D90 and he told me he had to use a sender that measured 1/8-27 NPT, which is VDO P/N #323 095 for my VDO temp gauge. However, when I went to install it I didn't have the correct bushing so it was a no go. I hadn't thought to measure the OEM sender first just to make sure that I had the correct thread count, but when I did measure it out to be M16x1.5, which is VDO part number #323-416.
So I beleive you can either purchase the M16x1.5 or the 1/8-27 NPT WITH a bushing kit. I had niether the bushing kit nor the M16x1.5. I went with the M16x1.5 and should be installing it later next week. I'll let you know how it turns out.
DJ
Temperature sender thread type/pitch? Neo Defender Technical Discussions 4 March 9th, 2006 02:40 PM
thread size snuffer Defender Technical Discussions 0 October 26th, 2005 08:24 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Rollcage light tab thread size read Defender Technical Discussions 4 January 28th, 2005 02:33 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
