thread sealant - Defender Source
Old April 1st, 2009, 05:54 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Exclamation thread sealant
Workshop manual says to use hylomar sealant on the fill and drain plugs of the transfer case and transmission. Can I use Permatex thread sealant w/PTFE? I can't find Hylomar anywhere by me. I don't want to order it online and wait. What does everybody use?
This is where I'm supposed to write something witty and funny; or something.
Old April 1st, 2009, 06:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
I just changed my transmission fluid and didnt use anything. oops
Old April 1st, 2009, 06:24 PM
JBOD77
Jonathan
taken from RAVE Workshop manual maintenance section for the transfer case:
"9. Thoroughly clean filler/level plug threads prior to
applying fresh ’Hylomar’ sealant. Fit plug
Tighten to 30 Nm, 22 lbf ft."
Barry, You don't have any leaking? have you run the truck since?
Funny thing, I just checked the owner's manual and it just says to clean and refit drain and fill plugs and doesn't mention the use of sealant.?.?.?.?.?.? So what gives? the owner's and manual the workshop manual will have to duke it out?
what do I do ??
Old April 1st, 2009, 06:44 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
A lot of people (myself included) just use some pipe sealant on the threads. I always just take the plug to the wire wheel to clean the threads of the old stuff, then get the liquid pipe sealant, spread a little around the threads and reinstall. No leaks at all, and you should be able to find it at any hardware store near you.
Old April 1st, 2009, 06:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
I guess I should check but I will say nothing leaked when I was filling it.
Old April 2nd, 2009, 08:48 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Oddly mine leaks from every place that has sealant. The drain and fill have no sealant and don't leak. Go figure.
Jimmy Buffett
Old April 2nd, 2009, 09:58 AM
No need for it. I coat them in anti-sieze.
Ron
Old April 2nd, 2009, 10:57 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Since I use the FSM I've never heard of using any kind of sealant. I just seal mine with good hopes and well wishes and it doesn't leak... much.
Old April 2nd, 2009, 12:55 PM
JBOD77
Jonathan
Whats FSM ?????
So the general consensus is no sealant. Maybe some anti seize if I', feeling generous.
sounds good.
Old April 2nd, 2009, 01:03 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Factory service manual
Old April 2nd, 2009, 01:07 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, there isn't really a need to seal it. I never used to, now its kind of hit or miss. If I think of it, and there is some laying around in the shop, I'll do it. Otherwise, I just wipe the plug clean and reinstall.
Old April 2nd, 2009, 02:35 PM
Tapered pipe thread connection should not need sealant if in proper shape and tightened properly. It does help lubricate the thread when tightening, which is a good thing. Any pipe dope should be fine.
Temperature sender thread type/pitch? Neo Defender Technical Discussions 4 March 9th, 2006 02:40 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread rating options chrisvonc Community News & Announcements 0 July 2nd, 2004 09:49 AM
Thread hijacking! TwisteD90 Misc. Chit-Chat 19 March 6th, 2004 03:23 PM
» Defender Registry
Defender
JAG
Slowgo
Danimal
Add your Defender
