Third world problem - Defender Source
Old October 17th, 2012, 01:27 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Third world problem
If you had to use either one in your 300TDi, would you opt for a 15-40 gas-engine oil, or straight 50 diesel oil? Figure you are in a tropical country, where ambient temp never drops below 72.
And yes, what you surmise is right. 50 weight is the only diesel-formulated engine oil in the market in oil-rich Venezuela as today. So much for socialism.
Old October 17th, 2012, 01:31 PM
15w-40 would be my vote.
Old October 17th, 2012, 02:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
mine too, similar situation here.
- Charles Eames
Old October 17th, 2012, 02:44 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
So far, we all agree. A pox on socialism!
Old October 17th, 2012, 03:17 PM
Does this mean that I can run my 200tdi on 15W40?
Old October 17th, 2012, 03:32 PM
Most people run the tdi on 15w40diesel spec oil or 5w40 synthetic diesel spec oil.
I don't have a rover tdi, but I like rotella 5w40 synthetic for my gas motors.
Old October 17th, 2012, 07:48 PM
oh my bad, I thought the OP was talking about oil as fuel !
stupid me
Old October 17th, 2012, 09:15 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Found this..."Diesel engine oil has more additives per volume. The most prevalent are detergent additives. This additive has several jobs, but the main ones are to neutralize acids and clean. Diesel engines create a great deal more soot and combustion byproducts. Through blow-by, these find their way into the crankcase, forcing the oil to deal with them."
So by using a petrol engine oil you may not get enough cleaning and the oil may not be able to handle the extra work. Do you have a Land Rover dealer near to you that you could ask what they use?
Land Rover 110
Old October 17th, 2012, 09:30 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
stupid me
40 is a little thick to burn! but you should try sunflower seed oil.... Might turn out cheaper than diesel...
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 17th, 2012, 09:36 PM
You could always mix the oils, to get some of the additional additives...
Old October 17th, 2012, 10:54 PM
I run regular 'ol Rotella 15w40 in mine so I think you'd be fine running a standard 15w40 in your Tdi.
Old October 18th, 2012, 06:53 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is what I use here:
- Charles Eames
Old October 18th, 2012, 07:02 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'd use the 15w40 and change it more frequently.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 18th, 2012, 07:43 AM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
That's my worry.
Hmm, that's an idea.
That's my plan so far.
Thanks for your help, folks!
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
D90 Ground Problem? cdnpaul Defender Technical Discussions 0 December 4th, 2003 03:36 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
