Third Brake Light - Defender Source
Old January 22nd, 2015, 01:37 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Third Brake Light
I bought a Third Brake Light from ECR, but it didnt come with a brake light.
Anyone have a recommendation on one to buy or where to get an original?
Thanks.
Old January 22nd, 2015, 03:38 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
NLA good luck
good luck with your search
Old January 22nd, 2015, 04:05 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Any idea for a decent replacement/similar light?
Old January 22nd, 2015, 04:20 PM
Search "corvette" or "third brake light" in the custom google search and you should find the previous discussions on sources and other ideas for replacement.
https://www.google.com/cse/publicurl...95:8zpbxe3x-t4
Old January 22nd, 2015, 04:25 PM
There is a similar hella unit sold by Rallylights. I posted a link in a similar thread. Now to find it...,
Bingo!
Originally Posted by Rocky View Post
Wanted to throw this out at you for a replacement high mounted brake light for ST. Its made by Hella. Obviously not an exact match for the LR unit, but possibly the best alternative out there. http://www.rallylights.com/hella-hl2...d-or-roof.html
Old January 22nd, 2015, 04:53 PM
Here's another idea.
Name:	3rd brake light.JPG
Old January 23rd, 2015, 09:42 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I just installed a Ron Francis Wiring led 3rd light on my 90. It is an led light bar in a pebble grained molded plastic housing...really nice for an aftermarket part.
http://www.ronfrancis.com/products.asp?dept=25
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 28th, 2015, 02:29 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Is it the RW-13?
Old January 28th, 2015, 03:05 PM
RW13 is internal. ST need a weather proofed external unit.
Old March 13th, 2016, 08:44 PM
LED Lightbars - 4" and 10" Versions-Ron Francis Wiring
Wayne, what model?
Originally Posted by pendy
I'm here for the D's
Old March 14th, 2016, 10:13 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Hi Charles, I used the RW43, the 4" straight model. It is plenty bright and visible. I have an interesting old French sticker on my upper rear window that I wanted to keep and the 10" is too big, plus the smaller one is a bit more discrete, but given the driving public, I'd use the bigger one if you can.
To clarify, this is for a SW, the light adheres to the inside of the rear window.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old March 15th, 2016, 02:11 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Looks like maybe the early 90s LeBaron's might fit as well.
Trunk Mounted Third Brake Light Customize Most Vehicles | eBay
Old March 15th, 2016, 04:31 PM
Aaah, no good for me then - I need this for a ST.
Ooh, that looks like it's worth a try, thanks. It even has an aluminum housing!
Old March 25th, 2016, 05:29 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Did you end up ordering one from flea bay? I got one and it seems like it is going to work pretty well size wise. Additionally much sturdier than the old light.
Old March 26th, 2016, 10:36 AM
Yes I did. Here is the end result
The pros are that it's roughly the same profile and has a sturdy aluminum case. The cons are that it is not as wide (maybe 1" less total), and requires 2 holes to be drilled into the mounting plate to mount it as-is. If you cared you could trim the mounting plate to make it look more like it belongs, and change the studs for a bolt going up (although I think then you'd have clearance issues with the light). I am sure you could get more creative, but my goal was to just get a decent functioning light and this does the trick.
I first tested it before opening it up.
ID:	145957 Click image for larger version
The existing wiring needs to terminate inside the light so it needed to be opened anyway, but I was also curious. I added connectors to match the bullet connectors on the truck, but if I were to do it again I'd just change connectors to something better.
ID:	145959 Click image for larger version
ID:	145960Click image for larger version
Here are side pics and close ups of it on the mounting plate. No, I'm not going to bother painting this black unless I get some serious flack. Heckle away.
ID:	145962 Click image for larger version
ID:	145963 Click image for larger version
Old March 26th, 2016, 07:30 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ah nice. I have a new brake bar that I have to paint anyways so I am going to pull it apart, sand it down and paint it black.
Old May 6th, 2016, 12:27 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Very nice that is the closest Non-OEM match that I have seen yet.
I can't believe someone isn't making a NAS 3rd brake light out of fiberglass or aluminum.
When I got my D90 in 2001, many NAS guys were pulling the 3rd brake light & bar and selling them cheap on the D90 Yahoo club. I got one for the bar, the light came with it as a bonus, but it was cracked so I threw the light away...in hindsight I wish I kept it and repaired it.
Back in the day, many NAS guys were pulling NAS parts i.e. the 3rd brake light bar, NAS step bumper, NAS consoles, the list went on, - they were going for more of an ROW Set up. Not the case any longer..
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old May 7th, 2016, 05:14 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Yep. And I was one of those guys! Sold my back bumper, side step bars and rear tire carrier. All dirt cheap I am sure.
Old May 12th, 2016, 03:35 PM
knab's Avatar
knab
Brandon Donald
97 ST, few RRCs, P38 HSE
I might have a solution to this. Will provide an update fairly soon.
Old May 13th, 2016, 08:43 PM
Cool. What are you making this out of? Do you have a solution for the lens too?
brake, ht
WTB - Defender Third Brake Light Bar w/light paydan Wanted 0 December 1st, 2011 02:28 PM
Rusty soft top third brake light bar and light evilfij Wanted 2 May 20th, 2009 11:26 AM
'94 D90 -- Third brake light? rmuller Defender Technical Discussions 2 September 9th, 2007 09:50 PM
Looking for new third - high brake Light Shake Wanted 4 February 13th, 2007 10:17 PM
third brake light bar Marc Weinstein For Sale - Parts 0 April 16th, 2004 08:03 AM
