Thick drive flange for metric hubs? - Defender Source
Old August 22nd, 2012, 08:55 AM
OK still trying to wrap my head around the effing minutia of Land Rover bodge build ups. This hub thing has my head in a swim. I think I now have the correct hubs that will work. They aren't all the same of course, the fronts are still the ABS ones, FTC942. I think I'm safe with those as long as I have the single line calipers and solid discs.
The rears are ones I got from Briggs, and they are non ABS RRC. They have the raised ribs on the back of the stud flange and appear to be metric hubs as well. Part number unknown but best guess is FTC1457.
I have the long 24 spline 110 half shafts front and rear. Fronts are Rover type, and the rears are Salisbury type. I guess I need either the KAM hub flange spacers so I can use the thin type drive flanges and the long axle shafts or I buy thick aftermarket drive flanges like the Terrafirma TF5806 ones, or I get all new axle shafts.
I am worried that the thick Terrafirma drive flanges are made for the early imperial axles and won't fit the later metric axles.
See? It's not all that simple is it?
Old August 22nd, 2012, 11:41 AM
24 spline is 24 spline. There is no difference. Metric etc just refers to the threads.
Old August 22nd, 2012, 11:45 AM
The concern is the drive flange bolt pattern. The hubs I have which seem to be most common have a larger bolt circle and center bore than the thick Defender 110 drive flanges i got with these axles.
Old August 22nd, 2012, 11:55 AM
Jeff your hubs are not the issue. It's the old defender drive flanges that do not fit any of the hubs I have, except for the one hub that was on the front axle.
Old August 22nd, 2012, 12:04 PM
Yahtzee!
Drive flange, swivel housing? hub? o2batsea Wanted 0 June 4th, 2012 09:42 AM
Heavy Duty Drive Flange Shearpin Defender Technical Discussions 3 May 22nd, 2012 03:41 PM
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
Drive flange bolts KevinNY Defender Technical Discussions 6 January 3rd, 2007 10:31 PM
