Thermostat question - Page 2 - Defender Source
Old March 29th, 2015, 10:42 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Halfway
1994 Silver DEFENDER 90 NAS SW
Old March 29th, 2015, 11:16 PM
Originally Posted by WG_moots View Post
I've had my D90 only a few days but I have noticed that the temperature gauge only goes up about 1/4 of the way up the gauge. I would expect it to run at about the 1/2 way point. What is the "normal" operating temperature of these engines (NAS '95 3.9L V8)? I suspect my thermostat is bad and is stuck wide open but just wanted to see where these engines should be on the temperature scale. thanks
Buy a genuine one. Run it the manufacturer intended.
Oh and if it's got a fail open type in there you gotta wonder what happened to cause it to fail ... Welcome to the cooling drama of a 20 year old engine.
Old March 30th, 2015, 11:34 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
And follow the service manual for proper flush and coolant filing technique to make sure you don't have air in the system.
Old March 30th, 2015, 11:45 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Where do I get the information you speak of for a carbed 3.5 v8? Thanks
1983 ROW D110
1970 Series III (Parting out)
Old March 30th, 2015, 02:14 PM
Diagnosis of overheating in a V8 Petrol Land Rover
start there
Old April 4th, 2015, 11:53 AM
usadventureracing
Brett
110
Thanks for all the feedback.
I do not use my heater, so I was wondering if there would be any issue with by passing the heater. So basically from the water pump into the back of the manifold?
1983 ROW D110
Old April 4th, 2015, 11:58 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Personally, I wouldn't bypass it even if I didn't use it as it may come in very handy if you ever get close to overheating---you can just turn it on for added cooling for your engine. Just my 2-cents...
Old April 4th, 2015, 12:00 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
spot on. I've had a few close calls over the years where the heating system saved my ass by blasting the cabin heat.
Another house question: 5 zone thermostat for AC? evilfij Misc. Chit-Chat 12 March 6th, 2015 11:59 AM
200TDi Thermostat Question: can a V8 82C be used? El Solis Defender Technical Discussions 2 July 8th, 2013 10:10 PM
Thermostat question. durangorover Defender Technical Discussions 0 May 28th, 2009 02:21 PM
replacing thermostat jstrong98 Defender Technical Discussions 5 May 25th, 2009 10:08 PM
Thermostat question~ obie Defender Technical Discussions 3 October 21st, 2004 12:44 PM
