Thermostat question~ - Defender Source
Old October 21st, 2004, 10:40 AM
obie's Avatar
obie
Patrick Oberg
'95 Disco ~ '04 E500 Benz
Does anyone know if I can use a thermostat other than LR for my '95 D-90?
"To prepare for a race, there is nothing better than a good phesant, some champagne and a woman." -- Jacques Anquetil
'04 E500 Benz
'02 Colnago
'95 Discovery
'79 Pearson '39
'67 Cal '25
Old October 21st, 2004, 11:00 AM
I would go to NAPA or similar and do a cross reference in the parts book, the rover v8 is just a ~30 year old GM V8...
Old October 21st, 2004, 11:26 AM
I have heard some Chevy ones will work, but they must have the jiggle pin that is in the rover ones, otherwise the system could airlock and over heat.
Old October 21st, 2004, 12:44 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Just drill a burping hole in a domestic. Thing is you want to use the LR gasket to seal it in. So no real time saved.
JP
legend in my own mind
thermostat
replacing thermostat jstrong98 Defender Technical Discussions 5 May 25th, 2009 10:08 PM
New Thermostat - Jumps to 220 ?? R. Kurk Defender Technical Discussions 3 March 19th, 2009 05:41 PM
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
How and Why to add an oil thermostat Hans Misc. Chit-Chat 0 February 18th, 2005 03:57 PM
Installing oil cooler thermostat Doug Defender Technical Discussions 8 February 18th, 2005 12:43 AM
