thermostat and gasket - Defender Source
Old July 10th, 2006, 09:24 PM
artm
Arthur Maravelis
97 SW
Went to replace the thermostat on the 90 (97) with a 160-degree (Stant 45356, NAPA 530060). However this one doesn't have a vent hole up top. Anyone using/recommend this?
Also, as to the gasket: can I use any old paper type or must it be metal? I don't mind metal but is it readily available from the chain stores?
BTW, The one I pulled out is a Waxstat 106.
Old July 10th, 2006, 10:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You can also drill in a vent hole if you want.
Also, I've used generic 2-hole paper gaskets without any problem.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 10th, 2006, 10:11 PM
artm
Arthur Maravelis
97 SW
Five minutes after I posted this I thought of just drilling it and using the plastic jiggle thing from the old one.
Old July 14th, 2006, 02:49 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
Talking
Originally Posted by artm
.... using the plastic jiggle thing .....
I love technical jargon that everybody knows EXACTLY what you are talking about.
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old July 14th, 2006, 04:25 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
The factory shop manual describes it as a "jiggle pin" - jus to be completely accurate.
Old July 15th, 2006, 12:53 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Update
Well that was easy enough y'all. Except for the chunk of skin I took off trying to gently remove the thermostat that was in place. That rubber sealing ring works great.
So I installed the factory recommended thermostat (part number ERR 3291) with WAXTAT stamped on it. The one I removed looks identical only it has WAXTAT and the number 101 stamped on the face.
I refilled the radiator and tested the truck. The temp guage read about half way between the half and 3/4 mark on the guage. I just drove around for about 5-6 miles in traffic with and without the AC on.
That sound about right?
Anything is possible, with the right tools...
Old July 15th, 2006, 01:26 PM
artm
Arthur Maravelis
97 SW
Well, as I have noted elsewhere, you can see temps of 225 at the halfway mark. If you're at 60% or so then you're probably at 230. I'd say if you're over the 50% mark then something's wrong. I've always been at just below that even with AC on the hottest days. Recently it crept up and that's when I also had noticeable coolant loss.
Old July 15th, 2006, 04:44 PM
ronward's Avatar
ronward
Redsrover
None - sadly
This is a 300Tdi in a 1984 One Ten. May be different than the NAS 90, but my next step is to have the radiator flushed.
Old July 15th, 2006, 06:21 PM
artm
Arthur Maravelis
97 SW
If you're normally running at 60-65% I think that's not right. Then again you are in GA so perhaps this is OK.
My other setup is the same (110, 300Tdi). Only had it past half-way once - really hot day, AC on, going up a hill in fourth, don't know the EGT's as I didn't have a gauge then. Let off the gas and temp went down.
Could have been first sign of my radiator going as I replaced it about a year later with very little miles put on since this incident - totally rusted out.
Will see how the new recore goes once I get the oil cooler lines done.
gas, thermostat
300 TDi Thermostat ronward Defender Technical Discussions 34 January 1st, 2013 12:09 AM
Changed Thermostat now coolant leak 97-D90-736 Defender Technical Discussions 3 January 3rd, 2010 11:09 PM
110 overheating or head gasket bcourtney Defender Technical Discussions 13 October 15th, 2009 09:37 PM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
