The ultimate travel spares list - Defender Source
Old September 8th, 2016, 10:54 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm putting together a spares shopping list for my trip to Baja next year so I thought I'd create a place where we can discuss spares for trips of various destinations and duration. Obviously a spares list is shorter on a short weekend trip and likely much longer on a long international trip.
First question (and I have searched) is regards to wheel bearings. Timken and SKF have been recommended. What size and part# (sources if available) do I need for my NAS D90?
Next, whats your favorite grease?
I was planning on getting a CV joint kit. Is my NAS D90 a 24 spline?
The head gasket sets I have been looking at, strangely do not include the head gasket. Do I buy that separately? Genuine the best way to go? OEM ok?
Old September 8th, 2016, 11:00 AM
a posted list should specify diesel vs gas. an ultimate list will differ between them.
Mark Kellgren
KM4BOR
Old September 8th, 2016, 11:06 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Good point. Vehicle specifics should be taken into account as well as duration. Domestic versus international as well. I have a couple of 'ultimate' 300tdi spares lists and while they can be helpful for reference I find it a little less useful to have a 'bring everything' list. Sure I can bring everything but I don't have room. What should I bring for two weeks in Baja and what should I not bring? I have very limited room in my D90 so I have to be very selective about what I bring.
Old September 8th, 2016, 11:13 AM
- BR37 for the wheel bearings, should be available literally at any Napa or auto parts store (pack a couple extras just to be safe, but I'd imagine you can find these anywhere even over the border). The BR37 is I believe the SKF number, but should cross-ref to Timken directly as the same or under "SET37" (which is the bearing/race LM603049/LM603011).
- the Valvoline Multipurpose "bucket-o-grease" (the red stuff) gets the job done just fine, or the Mobil 1 synthetic if you're got to spend more coin (I've had that side by side with the Valvoline and can't tell the difference).
- Yes 24 spline, but pony up and call Erik @ Lucky8 and get the Tibus HD set....they're pricey, but breaking CVs can be a pain in the arse so it's one of those worthwhile upgrades in my opinion.
Old September 8th, 2016, 11:33 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
There was a good discussion of this on the EE board:
Northwest by Ex-MOD - Page 2 - Expedition Exchange Bulletin Boards
It boils down to priorities and weight constraints. If you start packing too much crap, you sacrifice performance, safety, ride comfort, space, etc. The more trips I take, the less I bring. It's all about the essentials. Even in Baja, you're still no more than a day or two from a DHL delivery. The chances that you're going to replace a head gasket on a Baja trip are virtually nil. Same goes for CVs. If you're already running a HD driveline, don't even bother bringing spares.
Jack's list is spot on. I focus on steering and rolling and bring a few items that I've seen break time and again on trips: U-joints, shock absorbers, bushings, etc.
You can travel much lighter if you simply replace a lot of likely-to-fail items before you go. Don't wait for your U-joints to go out if they have many miles on them. Replace them at home.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 8th, 2016, 06:38 PM
I don't think you'll be replacing a wheel bearing on the side of the road if you maintain yours. A U joint would be a good spare as well as an extra brake bleeder nipple. The nipples can be installed on most junctions in the brake system to block off a damaged section.
Old September 8th, 2016, 10:27 PM
Wheel bearings are cheap and reasonably light so keeping two in the truck seems sensible.
Old September 8th, 2016, 11:02 PM
LR Max
Thomason, Max
1973 Series 3 109
-Extra T-stat (replace the fan clutch if its never been replaced, might as well clean out the radiator while you are at it, replace the hoses while you are in there, and keep the old hoses as spares. Oh and if you do the radiator, pull the heater core as well. Easy to do with the system empty and you'll enjoy it in the winter).
-Extra hose clamps. Much win there.
-Wheel bearing kit, Rovahfarm has pre-packaged kits. That should be fine.
-Extra fan belts/serpentine
-Extra air filter (or more, since it is the desert...)
-Extra oil filter
-Fuel pump and fuel filter. When that SOB goes, it sucks
-Spare fuses and that cool little fuse removal tool
-Wire brushes of all sizes, but most importantly, the size that looks like a tooth brush.
-Also an old tooth brush. Much win for cleaning crap out in the field
-Scotch brite. Like the tooth brush, you didn't know you needed this until you needed this. For ~$1.50 for a 3 pack, it won't break the bank. Or steal one from your kitchen. Whichevs.
-Extra brake fluid and 80w-90. Of course extra motor oil (and I guess extra trans fluid if you are running a slush box).
-An extra set of brake lines wouldn't hurt. Not too expensive and doesn't take up much, if any space.
Also if you are running a slush box, get a spare one of those clips that goes in the top of the shifter. Seems like the only time those things die is when you are on the trail.
-Just rebuild the driveshafts before you go. Cheaper and easier than carrying extra cardon joints and screwing around with them at 10pm at night with a hammer and some sockets.
Pull the axle shafts and inspect them. As with the driveshafts, easier to dick around with them at home than trying to limp home on 2 and a half wheel drive.
If you have a clutch, maybe look into an extra master and slave cylinder. Once again, one of those "this sucks" when it dies.
Adjust your parking brake while you are in there.
Misc nuts and bolts. Always come in handy.
Misc wire. Handy.
Drain the battery fully then see what kind of voltage the alternator puts out. If its shooting out ~14+ volts with a nearly dead battery, then it'll be fine. If it is struggling, then look into a rebuild/replacement. Easier to do it at home. Also you could pull the starter and give it a good cleaning. Top tip: a hi-lift handle works REALLY good for wacking the crap out of a starter.
Look into common sensors that fail. Probably a MAF and a crank/camshaft sensor. I think one or both of those can go, and it sucks. Dunno. Ask someone who works on EFI V8s.
Also if you have a distributor, replace all the wires, cap, and rotor. Take the old stuff and throw it in the spares. I occasionally eff up something and I just grab a spare. Oh and get a spare coil and whatever that piece between the ECU and dizzy that always dies. Research that.
Other than that, install LED bulbs and headlights so you don't have to worry about carrying spares. Roll out.
Make sure your factory bottle jack works. I know that sounds stupid, but bottle jacks can leak out all of their oil, and then they no workie. This sucks and the jack is actually super handy.
Oh and get a safety seal tire plug kit. Much win.
How good are your shocks? From my research, if you have crap shocks, Baja will let you know...and then you need shocks.
That is all I got. Wish you lived closer. One of my buddies has a "emergency spares" toolkit for a D1 he is trying to get rid of. I bet some/most of the crap is applicable to your truck. Also going through and simply having "a piece of mind" on most of this will go a long way. Getting it fixed at your leisure is better than trying to cobble together something to get you home.
Dunno. Just some ideas.
Old September 9th, 2016, 12:21 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
My friend Steffen Garthoff sent me this list checklist for Africa.
PERSONAL NEEDS
• FULL VACCINATIONS AND MALARIA TREATMENT AND YELLOW FEVER. (Bring Vacbook with)
• DRIVER’S LICENCE (letter to confirm driver license is recommended)
• VALID PASSPORTS
• PASSPORT COPIES
• LANDY PAPERS (ORIGNALS)
• COPIES OF THE LANDY PAPERS (MAIN AND THE DISK) COLOUR IS BEST AS IT CAN BE USED AS THE REAL THING (must be certified)
• ALL PERSONAL MEDICAL REQUIREMENTSAND MOSQUITO REPELLENT
• CAR INSURANCE PAPAERS
LANDY SPARES (THE HIGHLIGHTED ARE A MUST)WE CAN SHARE WHERE POSSIBLE
• WORKSHOP MANUAL
• WHEEL BEARING
• UNIVERSAL JOINTS​
• SEALS (OIL, DIFF, GEARBOX SEALS WHEEL BEARING ETC)
• AUX BELTS (FAN/ ALTERNATOR/WATER PUMP)
• FULL SERVICE KIT (FUEL FILTER, AIR FILTER, OIL FILTER) + ENGINE OIL X2 (3X FUEL FILTERS)
• SPARE DIFF, TRANSFER BOX OIL (EP90) ​
• SPARE GEAR BOX OIL (SEE SPECS) ATF OR MTF
• CLUTCH AND BRAKE FLUID​
• STEERING FLUID​
• THERMOSTAT ​(NO SPARE, WE CAN MACGYVER IT! IF WE HAVE TO)​​​
• SUMP PLUG + WASHER​
• RADIATOR PLUG
• RADIATOR HOSES OR METAL PIPE AS A REPAIR JOB ​​
• IDLER BEARING ​​​
• INJECTOR LOOM (TD5 ONLY)​​
• MASTER CYLINDER KIT OR UNIT​​
• SLAVE CYLINDER KIT OR UNIT​​
• ANTI FREEZE​​​
• FRONT SHOCK TURRET​​
• WATER/DIESEL FILTER AND PARTS
• FRONT SHOCK TURRET BRACKET AND NUTS​
• DRAG LINK BALL JOINT KIT
• LEFT AND RIGHT BALL JOINTS
• FRONT AND REAR BRAKES. (SPARE SET)
• COOLANT FOR RADIATOR
• FRONT AND REAR COIL
• FRONT AND REAR SHOCKS
• WATER PUMP AND FUEL PUMP KITS
• WHITE REFECTORS IN FRONT AND RED AT THE REAR
• DUAL BATTERIES
• COMPRESSOR
• SEED COVER
• GAS BOTTLES
• TENT 2 MAN
• DIESEL MIN 180L (1200KM IN ROUGH CONDITIONS OR 1500KM HIGHWAY)
• WATER MIN 80L EXTRA TANK AND HOSE AND FITTINGS ETC
• FULL SERVICE BEFORE WE LEAVE
• FULL SERVICE KIT X2 OILS X1 AND EXTRA FUEL FILTERS
• SPARE OILS FOR VEHICLE
• SPARE TYRES X2
• SNORKEL
• POWER POINTS AND LIGHTS
• FRONT WHITE REFLECTORS X 2
• CAR BATTERY CHARGER
• FRONT AND REAR RECOVERY POINTS​
• SAFE
• EXTRA KEYS
• FIRE EXSTINGUISHER/S
• TYRE PRESSURE GAUGE (PORTABLE)
• FRIDGE OR COOLER BOX
• SAND LADDERS
• WADING PLUG
• FIRST AID KIT
• 2X RED TRIANGLES
• 1X YELLOW REFLECTIVE VEST
• JUMPER LEADS
• SIPHON HOSE FOR JERRY CANS OR JIG PIPE
• TYRE PLUGS
• SPOT LIGHTS (OPTINAL)
• SPADE
• GPS
• 2 WAY RADIOS (CONVOY ONLY)
RECOVERY GEAR
• GLOVES
• WINCH AND CONTROL
• WINCH BLOCK
• SHACKLES
• TREE HUGGER
• TOW ROPE
• KINETIC STRAP
• EXTRA CABLE OR CHAIN
EMERGENCY EQUIPMENT
• FLARES / SMOKE MARKER
• NEEDLE AND THREAD
• SPACE BLANKETS
• FISHING LINE, HOOK ETC
• SIGNAL MORROR
• HAND HELD COMPASS
• TARP
TOOLS AND OTHER REPAIR GEAR (SOME IDEAS)
• FULL TOOL BOX
• WHEEL SPANNER
• HACKSAW (BLADES SPARE)
• ALLEN KEYS
• FILES
• 52MM SOCKET, 24MM SOCKET
• TYRE LEVERS X2
• Q 20
• DWF (WATER DISPERSER)
• HI LIFT JACK
• BOTTLE JACK
• POWER BAR
• LEVER PIPE
• PRATLEY’S STEAL- SUPA GLUE- LOCK TIGHT
• GASKET MAKER
• GASKET PAPER/ CORK
• DOUBLE SIDED TAPE
• NITTO TAPE- ELECTRICAL
• DUCK TAPE
• CABLE TIES
• RACKET STRAPS (SMALL AND BIG)
• FUEL HOSE + PRIMARY BULB
• FUSES
• DRILL BITS AND DRILL (HAND OR ELECTRICAL)
• ELECTRICAL WIRE
• SUN LIGHT SOAP
• BATTERY WATER
• CLAMPS
• LIGHT BULBS AND LENSES
• SPARE TYRE VALVES
• BLOUDRAAD
• GUN GUM
• SPARE WHEEL NUTS
• SCREWS, BOLTS, NUTS AND WASHERS
• COPPER WASHERS
• RIVET GUN AND RIVETS
• MONKEY WRENCH (BIG)
• PORTABLE VICE
• MULTI METER
• SAND PAPER
• HOSE CLAMPS
• WASHERS, BOLTS, SCREWS ETC (ASSORTMENT)
• TAPE MEASURE
• ELECTRICAL WIRE
• MAGNET
• MIRROR
• GREASE FOR WHEEL BEARINGS
• SOLDERING IRON 12V OR 220V AND SOLDER
• BRAZING ROD ???
• SPLIT PINS
• HAND CLEANER
• ENGINE CLEANER
• BATTERY WATER
CAMPING EQUIPMENT
• TABLE
• CHAIRS X2
• PEGS FOR CLOTHS
• TENT
• GROUND SHEET
• EXTRA ROPE (THIN)
• HAMMER FOR PEGS (4 POUND)
• AXE / SAW / PANGA
• SLEEPING BAGS + EXTRA FOR GROUND
• PILLOWS
• SOLAR SHOWER
• BASIN +PLUG
• TORCH/ CAMP LIGHT/ HEADLAMP BATTERIES ETC
• WATER PURIFICATION TABLETS
• MOSQUITO REPELLANT. SPRAYS, CREAMS, OR LISTERINE
• LAUNDRY CONTAINER / WATER TIGHT
KITCHEN EQUIPMENT
• GAS BOTTLES AND KEY
• COOKER ATTACHMENTS
• POTJIES POT
• KETTLE
• BRAAI GRID
• FIRE LIGHTERS
• POTS AND PANS
• CUTLERY – GRATER ETC
• PAPER PLATES
• CUPS ETC
• DRYING CLOTHS
• BLACK BAGS AND SMALL PnP BAGS
• CLING WRAP AND FOIL
• WASHING POWDER
• SUNLIGHT LIQUID
• CLOTHS PEGS
TECHNICAL AND POWER ETC
• ADAPTER AND CABLES – INVERTER AND CHARGES ETC
• BATTERIES
• RECHARGABLE BATTERIES AND CHARGER ETC
• SAT PH AND CBLES
• CAMERA AND ACCESSORIES
• VIDEO CAMERA AND ACCESSORIES
• GOPRO AND ACCESSORIES
• CRITTER CAM AND ACCESSORIES
• COMPUTER AND EXTRA BATTERIES
MEDICAL SUPPLIES
• MEDICINE FOR:
• COLDS
• HAY FEVER
• UPSET STOMACH
• INSECT BITES AND STINGS
• HEADACHES
• INFLAMMATION OF EYES
• SUNBURN
• TOOTHACHE
• BACKACHE
• BURNS
• MOUTH ULCERS
• CONSTIPATION
• DIARRHOEA
• CRAMPS
• REHYDRATE
• PLASTERS
• RUBBER GLOVES
• SPLINTS
• SPONGE
• STERILE PADS
• TWEEZERS
• SAFETY PINS
• CHARCOAL TABLETS
• MALARIA PROPHYLACTICS
• CALAMINBE LOCTION
• THERMOMETER
• HOT AND COLD COMPRESSES
• ANTIHISTAMINE CREAM / TABLETS
• SWABS
• BANDAGES
• GAUZE DRESSINGS
• ANTI-INFLAMMATORY GEL
• EYE DROPS
• ANTIBIOTIC CREAM
• ANTIBACTERIAL CREAM
• ANTISEPTIC CREAM
BOOKS ETC
• MAPS
• INFO BOOKS
• BIRD BOOKS
• SNAKE BOOKS
• ANIMAL TRACKS AND REPTILES BOOKS
• STAR BOOK
• BOARD GAMES/ CARDS ETC
Old September 9th, 2016, 07:43 AM
A headlamp switch and spare bulbs are good things to have.
Old September 9th, 2016, 08:22 AM
or you could drive a Land Cruiser and just carry booze
Old September 9th, 2016, 04:16 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Pretty damn true!
------ Follow up post added September 9th, 2016 04:18 PM ------
My only mobility kill on my 300tdi was some how I lost all bolts on a pulley.... That is now a pre flight check and I carry a few spare.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old September 9th, 2016, 04:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Not really.
I have friends traveling through Guatemala right now in a Land Snoozer. They have plenty more spares than booze. Sounds like a cool thing to say though.
Originally Posted by Ncrover725 View Post
Pretty damn true!
Old September 9th, 2016, 04:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I think we're very much in alignment on this one, Chris. I'm aiming to do as much maintenance before I go as I have time for. A new Allisport rad is on order. Break pads are going to be done. Break bleed was just done. I'm an obsessive "replacer". More often than not I just replace a whole assembly and keep the old as a spare.
I want to take as few spares as possible but I also want to make sure that what I bring has the highest potential of usefulness. Weight and size of spare is as important as is probability of failure. I've done my front bearings but not my rear ones and I may not get to them before departure so I will bring a set because they are very small and lightweight. I'm replacing the head gasket before I go because I have a leak already. Shock bushings are tiny and weight nothing so why not bring a set?
I thought there would be some value in having a thread like this to ramble on about different ideas and points of view. There was a good article in the most recent issue of Overland Journal about this but there's also value in discussing tips and tricks related to this, particularly when its vehicle specific.
Old September 9th, 2016, 04:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I've got JW Speaker LED headlights so... nay bother! That said it doesn't hurt to have driving lights or another set of already installed lights for independent redundancy should your headlights fail.
You shouldn't need a switch if you've rewired the headlights with a relay. The switch works fine when it is not overloaded.
Old September 9th, 2016, 04:38 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Not really. I have friends traveling through Guatemala right now in a Land Snoozer. They have plenty more spares than booze. Sounds like a cool thing to say though.
I have driven a troopy across Afghanistan for 10 months.....never one issue. Across Belize, guat, panama, Colombia, and Peru. Guess experiences vary. I love my rovers for what they are but don't fool myself when stuff matters.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old September 9th, 2016, 04:45 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep...saw this happen last year at MAR.
Headlights went out on a friends 90 and had to drive back to camp behind someone else because no aux lights!
Rent my
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
My kit has water pump, fuel pump, serpentine belt, u joint, hylomar, tire repair kit, electrical repair kit, 100 mph tape, jumper cables, and fluids. Flashlight / headlamp
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old September 9th, 2016, 05:50 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Same here. Driven Mexico, Belize, and Guatemala with no major issues.
Only things that went wrong were a lost harmonic dampener from the from axle, a bent Safari Gard tie rod, and brake failure in the mountains of Mexico which was remedied by pulling the ABS fuse.
Black Rhino Lives Matter
Old September 9th, 2016, 06:09 PM
My favorite grease is Valvoline Synpower with Moly.
spare
Spares Price List atlcruiser The Vendors Loft 12 September 16th, 2014 11:48 AM
Ultimate Freezer/Fridge for the Ultimate 4X4 Uncle Douglas The Flea Market 41 November 17th, 2010 01:31 PM
Ultimate Wiper Blade Cleaners COSteve Misc. Chit-Chat 1 January 17th, 2007 11:44 AM
Ultimate v8 ? thewap Defender Technical Discussions 26 July 9th, 2006 01:15 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
