The *official* 300 TDi Performance Thread - Page 3 - Defender Source
Old November 17th, 2008, 10:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Maryland 110
Joel,
Congrats on your purchase ! The trick on the vacuum lines is to drill into and tap the intake manifold and plumb the "t" thats on the output side of the turbo into the manifold-block off the current location. By doing this the wastegate and injection pump get a true manifold boost pressure instead of a signal before the air is pushed through the pipes and intercooler.
Hey,
Do you have a pic of this before and after? Or after? I'm confused.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 18th, 2008, 12:21 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Well what he means is that the most accurate way to determine the level of boost that actually enters the engine is to check it at the intake manifold (which is as far "downstream" as you can get in the intake system before entering the cylinder head). Remember temperature and volume have a large effect on pressure (which is what you want for the IP, boost guage, and wastegate) so in order to get the most accurate reading you need to get it from the manifold, rather than the turbo housing.
Remember the ideal gas law from high school physics? Well I do, because after sleeping through it I had to be tutored after school by a cute blonde with huge tits. 10 years later here is what I remember: pv=mrt
or more simply: Pressure x Volume = Moles x Ideal Gas Constant x Temperature.
See the air gets sucked out of the air cleaner, into the turbo, then blown through the tubing to the intercooler, through the intercooler, then finally to the intake manifold. In the process the actual pressure has almost certianly changed, due to the large volume of air it takes to fill the piping and intercooler, and the fact that (hopefully) the intercooler has dropped the temp of the air charge somewhat- affecting the "V" and the "T".
Someone feel free to correct me, like I said I am a noob when it comes to turbo and diesel theory.
Old November 18th, 2008, 07:55 AM
Joel nailed it. By fitting a bigger intercooler you get a cooler, more dense charge.
Old November 18th, 2008, 11:06 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I have talked endlessly about this. Have you not even read what I bothered to post in your thread? Here is a suggestion on how to implement on a 2.8l. You can see the line running to the intake instead of the intercooler housing.
Uuughh
This does not really have anything to do with moving the pressure signal source. Moving the source will help a stock intercooler as well.
Pics of tutor or band!
legend in my own mind
Old November 18th, 2008, 06:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Uuughh
Easy there Jimmy. I only see one mention of it and that is not the easiest to understand. Run it to the air intake, check. Then what. Thats why I was hoping for the pictures.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 18th, 2008, 10:21 PM
crown14's Avatar
crown14
Verticalscrote
Thats it.
Old November 18th, 2008, 10:25 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by crown14
Thats it.
So show me where you drilled an tapped the hole.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 18th, 2008, 11:27 PM
pendy's Avatar
pendy
jim pendleton
89'd90
There is a plug at the back of the intake manifold. You can remove it and tap to 1/4 pipe. Or tap the plug to 1/8" pipe. You want to plumb in the injection pump and turbo wastegate. I would run the boost gauge from there as well. So three lines tee into the back of the intake manifold.
Buy em' books and send em' to school- geesh
Old November 19th, 2008, 09:43 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Where are my pictures!!
Seriously though, it would still be helpful, but I think I can get it done without. Thanks
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 25th, 2008, 11:24 AM
crown14's Avatar
crown14
Verticalscrote
Ill try and remember to take some when I get around to doing mine.
Old November 25th, 2008, 05:11 PM
crown14's Avatar
crown14
Verticalscrote
After looking all over, the EGR block off looks as good a place as any for the EGT probe- where have you guys installed yours?
Old November 25th, 2008, 09:35 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
This works fine but it will need to be instaklled a 45 degree angle.
Call me David, I'll walk you through the moving of said boost control plumbing...
Keith
Big, Red and ... aaa Red..
Old November 25th, 2008, 10:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks! Will do.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 26th, 2008, 06:56 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I've been playing with running the boost signal to the IP from the turbo AND the intake which gives a nice "blend" of the instant effect at the turbo and the more accurate actual pressure from the manifold and the resulting quicker response. Gave a better "throttle" response and allowed a little more pre boost spring pressure (star wheel) so snappy response with less smoke.
I'm running the signal to the wastegate (and the boost gauge) from the manifold for accuracy where it may count.
Matt Browne
Old November 26th, 2008, 07:40 AM
crown14's Avatar
crown14
Verticalscrote
That might complicate things a little...
Old November 26th, 2008, 08:24 PM
crown14's Avatar
crown14
Verticalscrote
Sure enough, the EGR block off is NOT really a viable option since you want to probe to actually be directly in the exhaust flow, and the design of the manifold sorta hampers this. I could fabricate a plate that bolts on like the block off and positions the probe correctly, but drilling and tapping the manifold is looking like the better option. But WHERE?? I cant find a good spot really. Might have to just drill right into the "log"?
I DID manage to get the plug in the rear of the intake drilled, tapped and fitted with a barb so I could run the wastegate and boost guage properly. The reference for the IP I left in its original position for now, but thinking about it after the fact this could be problematic if I developed a boost leak while on a long trip, might overfuel?
Took a few pics, but apparantly have to resize them all. [img]images/smilies/rolleyes.gif[/img]
ALSO I fiddled with the pump a little, one turn on the smoke screw, 90 degrees on the diaphragm, and 6 clicks on the star wheel. Not really the WOW I was expecting, and I may need to back off the smoke screw some, I will fine tune it once I get the EGT situated.
Old November 27th, 2008, 05:57 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Sure enough, the EGR block off is NOT really a viable option since you want to probe to actually be directly in the exhaust flow, and the design of the manifold sorta hampers this. .
...errr not really. I've installed many in this spot as well as the same cast area in the 200 manifold and get what i would consider to be a very good result.
I only say this as I have also installed directly in the manifold with the same resulting readings. The trick is to just get the probe in at an angle and as deep as possible and you're good.
ID:	16597   Click image for larger version
Matt Browne
Old November 28th, 2008, 10:51 PM
crown14's Avatar
crown14
Verticalscrote
Nice, might switch back to that plan then. Didnt really want to drill into the manifold.
1st pic- showing location of 17mm plug on rear of intake manifold
2nd- plug in vise ready to be drilled/tapped (no drill press at the time)
3rd- plug with new street elbow and hose barb installed
4th- plug reinstalled into manifold
5th- boost guage and wastegate now plumbed to intake manifold
6th- block off the old port (note I still have the IP reference signal in the original spot)
7th- anyone know what this blue plug is for? cylinder head temp?
8th- it appears that my engine used to use a TPS? it is no longer hooked to anything however.
ID:	16630   Click image for larger version
ID:	16632   Click image for larger version
ID:	16634   Click image for larger version
ID:	16636   Click image for larger version
Old December 13th, 2008, 10:14 AM
crown14's Avatar
crown14
Verticalscrote
Thought I would mention I finally got my probe installed in the EGR block-off, using Matt's method above.
Old December 13th, 2008, 01:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Great pics. Thank you very much.
Have you driven it yet? Did you notice any difference in performance?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
300 tdi, tdi
300 Tdi A/C question... roverboy Defender Technical Discussions 3 September 17th, 2005 02:15 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
