"The Official" 200tdi Performance/import/install thread! - Page 3 - Defender Source
Old February 6th, 2009, 09:18 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi pics
The engine is here!
A few problems: Stuff missing off the pallet
A few concerns: Look at the date on the air filter, Seller MIA
I hope it runs better than it looks.
It actually doesn't look to bad, but could of been packed much better!
Is there anywhere you can look up the serial numbers of the engine, tranny, transfer case, to find the build date?
ID:	17676   Click image for larger version
ID:	17678   Click image for larger version
ID:	17680   Click image for larger version
Old February 6th, 2009, 10:57 AM
pendy's Avatar
pendy
jim pendleton
89'd90
That will make your truck use more fuel. As I have said before. Adjust the base up to increase spring pressure so that fueling comes in at a higher boost. A over simple explanation.
Originally Posted by Red90
As I may or may not have mentioned....
At least on my 200TDI, the boost fueling plunger runs out of travel at around 13 psi. So operating at a boost higher than that and you will not get any more fueling. You need to put in a larger spring and re-adjust all of the fueling to get things correct.
legend in my own mind
Old February 6th, 2009, 11:41 AM
That will help a bit, but you are not getting control at 20 psi with a preload adjustment. It is too far of an increase without changing the spring.
Old February 6th, 2009, 11:42 AM
pendy's Avatar
pendy
jim pendleton
89'd90
What do you want to source a spring from? Maybe I have one around.
Old February 7th, 2009, 09:17 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi Gauges
I've gotten various numbers for gauges (VDO) and Senders. Some confusion with V8, 300tdi, etc.
I was wondering if anyone has Part numbers for the 200tdi gauges?
H20 Temp:
H20 sender:
Tach:
Fuel:
Boost:
Boost Hose Kit:
Volt:
Voltmeter Extras Needed:
Oil Pressure:
Oil Presure Sender:
Exhaust Gas:
EG kit #:
I have found many numbers by searching, but didn't want to cloud the issue!
Old February 28th, 2009, 06:47 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Block Heater
Which freeze out plug would be the best location for a block heater on a 200?
Old February 28th, 2009, 07:00 PM
The easiest to get to.The heater is going to warm all the coolant so pick the easiest to access.
Old February 28th, 2009, 07:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, so theres enough room behind all of them?
Did you send the latch to me in a Blackberry Box? I think I got it today.
Old February 28th, 2009, 10:24 PM
Yes. That's it.
Old March 26th, 2009, 03:26 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just tried my block heater, its a no go. Looked on RN can't figure out which one I need?
200tdi, import, tdi
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
200tdi Performance thread tomaco1 Defender Technical Discussions 3 November 26th, 2008 08:10 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread rating options chrisvonc Community News & Announcements 0 July 2nd, 2004 09:49 AM
