The good, the bad and the Ugly. - Page 2 - Defender Source
Old September 22nd, 2009, 06:14 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You need to start collecting a few other things for the frame swap. Brake and fuel lines have been mentioned. Stainless bolt kits are floating around for the D90. I suspect the skidplate under the fuel tank may be toast with all the frame rust. Also is there any bulkhead rust? If it has carpeting, pull it back and look in the footwells.
Old September 22nd, 2009, 06:45 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Gunmaker
okay here is a larger picture of my avatar.
Michael
Oh snap! That is hilarious! Glad the D90 survived.
Semper Fi!
Old September 22nd, 2009, 07:28 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
I was aware of the rust and had planed on replacing the frame in a few years. It was worse than I thought or was told. So it was a bit of a surprise when it rolled off the truck. Worst part is the interior is really pretty good as is the body. The body has a few dents in it but the rust. Still I am pretty sure I will be okay.
My original plan was to drive it for a few years and when the engine got bad do a restoration and swap out the frame and put in a TDI. That has changed and now am looking at some sort of solution.
Great point about welding on the frame. I really don't plan on it but then I am not sure if I will ever need to or want to down the road. Just one more thing to think about. I am not going to make it a rock crawler just a good 4x4 and daily driver.
There is some bulkhead rust under the drive side foot well but surprisingly there is not really any other rust. Oh the rust on the foot well is on the underside of the truck. If you pull the carpet back you can not tell that there is rust.
Michael
Old September 22nd, 2009, 09:39 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
First off, congrats on the new truck. That's my favorite color on the 90. I'm typically not a blue car person but I just think it goes well with the boxy shape.
My guess is you'll find some more demons when you start taking it apart. If the rust is that bad where you can see it, there has to be more to be discovered. However, if you are replacing the frame, it will be much easier to handle things when apart. Luckily there is a great knowledge base on this site along with others that have done the same thing with documentation.
Crazy story and pic. I don't think you could plan a stunt as "good" as that came out.
